Esri Leaflet Related Records and Charting?
1379
10-29-2016 04:36 PM
BruceGodfrey
Does anyone have a working example or a suggestion on a charting Javascript library to use with esri-leaftlet-related (GitHub - jgravois/esri-leaflet-related: esri leaflet plugin for querying related tables)?
For example, how would you produce a bar chart the # of bikes over time for this example: https://johngravois.com/esri-leaflet-related/index.html
I was thinking Cedar (cedar.js | Esri Cedar) might work well but I don't quite see how to use it with esri-leaftlet-related.
Thank you,
-Bruce
Tags (3)
JohnGravois
i could be wrong, but i don't think there's anything cooked into Cedar to simplify creating a chart that plots the appearance of individual records in a table over time. You can see an example of a generic leaflet D3 chart plugin that displays elevation from input GeoJSON and GPX files below.
GitHub - MrMufflon/Leaflet.Elevation: Leaflet plugin to view height profile of GeoJSON- and GPX poly...
We integrated the plugin in an esri-leaflet-gp demo here:
https://johngravois.com/esri-leaflet-gp/elevation.html
I'm happy to lend a hand if you decide to tackle the project you described and get stuck along the way. Just write again here or log an issue in esri-leaflet-related and share what you've already tried.
JohnGravois
BruceGodfrey
Thank you John.  I'll looking into the demo and see what I can come up with. -Bruce
SethLewis1
Occasional Contributor III
Take a look at dc.js (dc.js - Dimensional Charting Javascript Library )
Here's a project that I came across that uses Leaflet in combination with dc.js & d3. Perhaps worth a look.
GitHub - austinlyons/dcjs-leaflet-untappd: Beer Drinking Data Vizualization using dc.js, Crossfilter...
BruceGodfrey
Thank you Seth.  I'll give the librayr and example an in-depth look to see how it might fit into my project.  -Bruce
