I can't seem to configure my popup for a certain layer
5996
19
11-02-2016 09:16 AM
JoshWhite
Regular Contributor III
I can't seem to configure a popup in ArcGIS Online.  I have enabled and disabled multiple times and even removed the layer and readded it.  I click on Configure Popup and nothing happens.  What is going on with this?
Josh White, AICP
Principal Planner
City of Arkansas City
JoshWhite
Ultimately, this had to do with a specific feature class that had somehow become corrupted.  I exported it out to a file geodatabase and then imported it back into my SDE.  Here is the solution write up by Support:
Issue was due to a specific feature class. Able to configure pop-ups after exporting this feature class out to a new feature class and then publishing.
Josh White, AICP
Principal Planner
by Anonymous User
Not applicable
I have a few questions about the pop-up issue:
- Which browser are you using?
- Does this same behavior happen in other browsers?
- Is the feature layer shared with the public? If so please provide a link.
- Is this a hosted feature service or an ArcGIS for Server service?
Katie
JoshWhite
I was using Chrome but I tried Internet Explorer and I am experiencing the same behavior.
http://www.arcgis.com/home/webmap/viewer.html?webmap=5d820fc093f7463d8ae732d282c5167b
The service is an ArcGIS for Server service.
The problem just cropped up and had not been occurring before.
Josh White, AICP
Principal Planner
KellyGerrow
Esri Frequent Contributor
Hi Josh,
I can enable pop ups on most of the layers in this web map, but not the annotation layer. Which layers are you trying to enable pop ups for?
-Kelly
JoshWhite
I am working with spaces.  I can enable the popups just fine, I just can't configure them.  For instance, for the link I wanted to change the text to something besides More Info and there are several fields that are duplicates that I would rather just turn off.  Normally these things are simple to fix but only if the configuration dialog comes up.  When I do step 3 for Configure popups at Configure pop-ups—ArcGIS Online Help | ArcGIS
  1. Browse to the sublayer that contains the feature data you want to configure in a pop-up, click More Options More Options, and click Configure Pop-up.
Nothing happens.
Josh White, AICP
Principal Planner
by Anonymous User
Not applicable
Hello White,
You can hide or unselect those fields which are not required to show in popup ..
this is the best way and also improve your web page rendering and performance also improve.
JoshWhite
That's exactly what I am trying to do, but when I hit configure, nothing happens.
Or maybe I am missing what you are saying.  Are you suggesting I do this in ArcMap before I publish the service?  I can certainly agree with you on that point, but I still need the ability to change the text that shows up for the link.  "More info" doesn't really make sense for what I am wanting the user to do.
Josh White, AICP
Principal Planner
by Anonymous User
Not applicable
Hi Josh,
I would like to get a support case created for this issue. I will send you a direct message.
Katie
JoshWhite
Thanks, I have started the process
Josh White, AICP
Principal Planner
by Anonymous User
Not applicable
Hi Josh White,
If you have time could you post the solution provided from the Support case? This may be helpful for other community members who come across this post.
Thank you,
Katie
