Parcel Fabric Line Point Issue
857
11-03-2016 09:22 AM
MichaelSnook
Occasional Contributor III
This is better described with images...basically when adding a line point to one part of a section it affects a far-away portion of the section...any ideas as to why this is happening would be great!
Section2.jpg is an image of the entire section with the areas highlighted in red.
AffectedAreaBeforeLinePoint.jpg - self explanatory
AffectedAreaAfterLinePoint.jpg - self explanatory
As far as I can tell, these areas are independent of each other.
Thanks!
AmirBar-Maor
Hello Mike,
it is best to submit a technical support case if you want someone to look at your issue using your data, but until then here are a few guesses:
  1. Parcel(s) have bad misclose and/or rotation and or scale that might modify one or more parcels. Use the QA add-in to check data quality
  2. Check you Parcel Fabric properties (Catalog window). Check your point behavior and line point tolerances.
  3. Make sure the line in question is not a curve
  4. The distance of the gap is not clear - make sure you are not zoomed beyond the XY Resolution.
  5. Missing join links? Unjoin the parcels
  6. Run regenerate sometimes help
Again, those are all guesses for now
Amir
