Geoprocessor returns an invalid value.
925
5
11-07-2016 01:16 PM
GaryWhitcher2
Why does my geoprocessor return a different Shape_Length when I run it from a widget then when I run it manually from Server Manager
DanPatterson_Retired
is one in geographic coordinates? and the other in projected coordinates?  Have a check
GaryWhitcher2
How do I determine the map projection of the map? Isn't it based on the MXD i published as a service
you didn't show the numbers... so I am guessing.
geographic coordinates will show up in the range -180 to 180 and -90 to 90
If they are big numbers... they are projected
RobertScheitlin__GISP
Gary,
   Since you are talking a web app (viewer for flex) then the maps projection is determined by the basemap used. If you are using an esri basemap then the maps projection would be 102100 web mercator. If you are not using an esri basemap then the maps projection would be determined by the basemap that you choose to use.
GaryWhitcher2
Thats got to be it. I am using a base map and the map service is using GCS_North_American_1983. Thanks guys.
