enabling http and https - can't access anything through http
1033
11-14-2016 09:43 AM
South_JordanCity_of
Hi all!
I'm trying to enable the setting 'enable http and https' on our server, and after doing so, I can reach our services through https using port 6443, but I can't access them through http using 6080 anymore. All of our services, maps and applications are based on http and 6080, but now we need one service to be accessed securely through https because of an external application that needs a basemap to be ssl secured.
I assume that if I was to enable https only, I would have to recreate all of our maps and point them to service using https instead of http, correct?
Any idea how I can enable http and https for now and still be able to access our services through http and port 6080?
Thanks for your help,
Marc Seliger
AdrianWelsh
MVP Honored Contributor
Hi Marc,
Did you ever get this resolved?
RandallWilliams
Which version and what's the error? Mixed mode should allow access through both HTTP and HTTPS connections.
South_JordanCity_of
Sorry for the late response..
Yes, I was able to resolve this. I changed the settings to http and https, and both urls (secured and unsecured) are working now. Our IT dept. had to make some changes regarding the certificate, I believe that's what was causing the issue.
Marc
