How to use a feature layer map for mobile version?
1429
5
11-18-2016 09:54 AM
BulbulMajumder1
New Contributor III
I am trying to use the mobile version for my code. When I am trying to use
Getting Started - Mobile  this code along with 3.13/3.17/3.18 version with the feature layer of java script but whenever I am trying to use
"dojox/mobile",
"dojox/mobile/parser",
"esri/sniff",
"dojox/mobile/deviceTheme",
"dojo/dom",
"dijit/registry",
"dojo/on",
"dojox/mobile/ToolBarButton",
"dojox/mobile/View",
"dojox/mobile/ContentPane"
from the "Getting Started" its not showing up and giving me an error....I can provide my code upon request....Any help will be greatly appreciated.
Thanks and regards
Bulbul
RobertScheitlin__GISP
Bulbul,
   I would have to see your code to tell you where you error is. There is no reason why you can not use FeatureLayer class when using the compact API or dojox mobile.
BulbulMajumder1
New Contributor III
Thanks Robert,I am attaching my code with this reply.
Bulbul
 the js I am using is
Script: productionWellsView313.js
/* Script updated to AMD-style formatting */
var map;
var navToolbar;
require([
"esri/config", "esri/map", "esri/arcgis/utils", "esri/geometry/Extent", "esri/SpatialReference",
"esri/InfoTemplate", "esri/dijit/Legend",
"esri/tasks/LegendLayer", "dojo/on", "dijit/registry", "esri/dijit/BasemapGallery", "esri/geometry/webMercatorUtils",
"esri/geometry/scaleUtils", "esri/dijit/OverviewMap",
"esri/dijit/Scalebar", "esri/dijit/HomeButton",
"esri/dijit/Popup", "esri/dijit/PopupTemplate", "esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer",
"esri/symbols/SimpleMarkerSymbol", "esri/tasks/GeometryService",
"dojo/dom", "dojo/dom-construct", "dojo/parser", "dojo/_base/array",
"dijit/form/HorizontalSlider", "dijit/form/Button",
"dijit/form/DropDownButton",
"dijit/form/TextBox",
"dijit/form/CheckBox",
"dijit/Menu",
"dijit/MenuItem",
"esri/Color",
"dijit/layout/AccordionContainer",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dojo/domReady!"
function (
esriConfig, Map, utils, Extent, SpatialReference,
InfoTemplate, Legend,
LegendLayer, on, registry, BasemapGallery, webMercatorUtils,
scaleUtils, OverviewMap,
Scalebar, HomeButton,
Popup, PopupTemplate, ArcGISTiledMapServiceLayer,
ArcGISDynamicMapServiceLayer, FeatureLayer,
SimpleMarkerSymbol, GeometryService,
dom, domConstruct, parser, arrayUtils,
HorizontalSlider, Button, DropDownButton, TextBox, CheckBox, Menu, MenuItem, Color,
AccordionContainer, BorderContainer, ContentPane, TitlePane
parser.parse();
/* Define the initial extent for the map area */
//var initialExtent = new Extent({ "xmin": -12972052.788, "ymin": 5429282.436, "xmax": -11508904.02, "ymax": 6363263.470, "spatialReference": { "wkid": 3857 } });
// var llExtent = new Extent(-12972052.788, 5429282.436, -11508904.02, 6363263.470, new SpatialReference({ "wkid": 3857 }));
var legendLayers = [];
var popupOptions = {
markerSymbol: new SimpleMarkerSymbol("circle", 32, null,
new Color([0, 0, 0, 0.25])),
marginLeft: "20",
marginTop: "20"
var popup = new Popup(popupOptions, domConstruct.create("div"));
var map = new esri.Map("map", {
//extent: initialExtent,
basemap: "topo",
center: [-110, 47],
zoom: 6
//map.setExtent(llExtent);
/* Add the BASEMAP GALLERY from ESRI */
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
//basemapGallery.startup(); // This is commented out since handled in DDLB
/* Home Button */
var home = new HomeButton({
map: map
}, "HomeButton");
home.startup();
/* Scale Bar */
var scalebar = new Scalebar({
map: map,
/* Overview Map */
var overviewMapDijit = new OverviewMap({
map: map,
attachTo: "top-right",
height: 100,
width: 100,
visible: true
overviewMapDijit.startup();
map.on("load", function () { dojo.byId("mapName").innerHTML = "<strong>Current Basemap:</strong> Topographic"; });
/* When the map is loaded enable coordinate display in DIV */
map.on("mouse-move", showCoordinates);
map.on("mouse-drag", showCoordinates);
/* When the extent changes show the changed scale in DIV */
map.on("extent-change", changeScale);
/* When the extent changes show the new extent in DIV */
//map.on("extent-change", showExtent);
/* When the slider changes, change the opacity */
on(registry.byId("sliderOpacity"), "change", changeOpacity);
/* Create the DDLB for the basemaps layers and place
it in the DIV labeled "basemapMenu" in the Layers
section */
on(basemapGallery, "load", function () {
dojo.forEach(basemapGallery.basemaps, function (basemap) {
//Add a menu item for each basemap, when the menu items are selected
dijit.byId("basemapMenu").addChild(
new dijit.MenuItem({
label: basemap.title,
onClick: dojo.hitch(function () {
basemapGallery.select(basemap.id);
dojo.byId("mapName").innerHTML = "<strong>Current Basemap:</strong> " + basemap.title;
/* Create the legend */
map.on("layers-add-result", function () {
var legend = new Legend({
map: map,
layerInfos: legendLayers
}, "legendDiv");
legend.startup();
1:500,000 MBMG GEOLOGY LAYER DEFINITIONS
/* Add the MBMG 1:500,000 geology layer as a Tiled Map Service Layer */
var geo500Layer = new ArcGISTiledMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Geology/Geology_500k/MapServer", { id: 'geo500Layer', opacity: 0.2 });
// map.addLayer(geo500Layer);
STREAMS LAYER DEFINITIONS
/* Add the STREAMS layer */
var streamLayer = new ArcGISDynamicMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Surface/Streams/MapServer", { id: 'streamLayer' });
//map.addLayer(streamLayer);
legendLayers.push({
layer: streamLayer,
title: "Streams"
HYDROLOGIC UNIT CODE LAYER DEFINITIONS
/* Add the HUC layer */
var hucLayer = new ArcGISDynamicMapServiceLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Surface/HUCs/MapServer", { id: 'hucLayer' });
legendLayers.push({
layer: hucLayer,
title: "HUC Boundary"
//map.addLayer(hucLayer);
GWAAMON LAYER DEFINITIONS
Create a PopupTemplate for the GWAAMON layer - Superceded
by the InfoTemplate definition below
var gwaamonTemplate = new PopupTemplate({
title: "GWAAMON Site Details",
fieldInfos: [
{ fieldName: "gwicid", visible: true, label: "GWIC Id" },
{ fieldName: "site_name", visible: true, label: "Site Name" },
{ fieldName: "site_type", visible: true, label: "Site Type" },
{ fieldName: "township", visible: true, label: "Township" },
{ fieldName: "range", visible: true, label: "Range" },
{ fieldName: "section", visible: true, label: "Section" },
{ fieldName: "qsection", visible: true, label: "Q Section" },
{ fieldName: "swl_meas", visible: true, label: "# Meas" },
{ fieldName: "samples", visible: true, label: "W Qual" },
{ fieldName: "field_visits", visible: true, label: "F Visit" }
showAttachments: true
/* Create a new InfoTemplate for the GWAAMON layer 2014-12-29 */
var gwaamonInfoTemplate = new InfoTemplate();
gwaamonInfoTemplate.setTitle("GWIC Record ${gwicid}");
gwaamonInfoTemplate.setContent("<table>" +
"<tr valign='top'><td style='white-space:nowrap;'>Site Name</td><td>${site_name}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Well Log</td><td><a target='_newwellwin' href='http://mbmggwic.mtech.edu/sqlserver/v11/reports/SiteSummary.asp?gwicid=${gwicid}&agency=mbmg&reqby=M&'>View</a></td></tr>" +
"<tr><td style='white-space:nowrap;'>Site Type</td><td style='white-space:nowrap;'>${site_type}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Location</td><td style='white-space:nowrap;'>${township} ${range} ${section} ${qsection}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Water Levels</td><td>${swl_meas} <a target='_newwellwin' href='http://mbmggwic.mtech.edu/sqlserver/v11/reports/WellHydrograph.asp?gwicid=${gwicid}&agency=mbmg&reqby=M&'>Graph</a></td></tr>" +
"<tr><td style='white-space:nowrap;'>Samples</td><td>${samples}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Field Visits</td><td>${field_visits}</td></tr>" +
"</table>");
var gwaamonFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Water/GWAAMON_wells/MapServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["gwicid", "site_name", "site_type", "township", "range", "section", "qsection", "swl_meas", "samples", "field_visits"],
infoTemplate: gwaamonInfoTemplate
legendLayers.push({
layer: gwaamonFeatureLayer,
title: "MBMG GWAAMON Network"
//map.addLayer(gwaamonFeatureLayer);
GWIC LAYER DEFINITIONS
/* Create a new InfoTemplate for the MBMG SWAMP layer 2014-12-29 */
var gwicInfoTemplate = new InfoTemplate();
gwicInfoTemplate.setTitle("GWIC Record ${GWICId}");
gwicInfoTemplate.setContent("<table>" +
"<tr><td style='white-space:nowrap;'>Total Depth</td><td>${total_depth}</td></tr>" +
"<tr><td style='white-space:nowrap;'>Static Water Level</td><td>${swl}</td></tr>" +
"</table>");
var gwicFeatureLayer = new FeatureLayer("http://mbmgmap.mtech.edu/ArcGIS/rest/services/Water/GWIC_wells_map_service_250k_vis/MapServer/0",
infoTemplate: gwicInfoTemplate,
outFields: ["*"]
legendLayers.push({
layer: gwicFeatureLayer,
title: "GWIC Wells"
/* Add the layers to the map that have been defined above */
map.addLayers([geo500Layer, streamLayer, hucLayer, gwaamonFeatureLayer, gwicFeatureLayer]);
/* Turn on mouse features */
// map.enableScrollWheelZoom();
//map.enableDoubleClickZoom();
Build the check boxes that represent the layers
that have been added to the map above.
//add check boxes
arrayUtils.forEach(legendLayers, function (layer) {
var layerName = layer.title;
var checkBox = new CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible
checkBox.on("change", function () {
var targetLayer = map.getLayer(this.value);
targetLayer.setVisibility(!targetLayer.visible);
this.checked = targetLayer.visible;
//add the check box and label to the toc
domConstruct.place(checkBox.domNode, dom.byId("toggle"), "after");
var checkLabel = domConstruct.create("label", {
"for": checkBox.name,
innerHTML: layerName
}, checkBox.domNode, "after");
domConstruct.place("<br />", checkLabel, "after");
/* Re-size the infoWindow to fit the standard contents */
map.infoWindow.resize(300, 150);
/* Function to change the opacity of a layer */
function changeOpacity(op) {
var newOp = (op / 100);
geo500Layer.setOpacity(newOp);
/* Show Lat/Long coordinate pairs */
function showCoordinates(evt) {
var mp = webMercatorUtils.webMercatorToGeographic(evt.mapPoint);
dom.byId("currentPosition").innerHTML = "<strong>Lon:</strong> " + mp.x.toFixed(6) + "<strong> Lat:</strong> " + mp.y.toFixed(6) + " ";
/* New changeScale function uses esri/geometry/scaleUtils */
function changeScale() {
var scale = scaleUtils.getScale(map);
dojo.byId("currentScale").innerHTML = "<strong>Scale:</strong> 1:" + addCommas(scale.toFixed(0));
/* Custom function to add commas to a string (number) */
function addCommas(inVal) {
inVal += '';
x = inVal.split('.');
x1 = x[0];
x2 = x.length > 1 ? '.' + x[1] : '';
var rgx = /(\d+)(\d{3})/;
while (rgx.test(x1)) {
x1 = x1.replace(rgx, '$1' + ',' + '$2');
return x1 + x2;
/* Extents */
function showExtent() {
var s = "";
s = "XMin: " + map.extent.xmin + "<br/>"
+ " YMin: " + map.extent.ymin + "<br/>"
+ " XMax: " + map.extent.xmax + "<br/>"
+ " YMax: " + map.extent.ymax;
dojo.byId("extentDisplay").innerHTML = s;
and the html is
<!DOCTYPE html>
<!--[if lt IE 7]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie6"> <![endif]-->
<!--[if IE 7]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie7"> <![endif]-->
<!--[if IE 8]> <html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default ie8"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="layout_1 page_501 layout_responsive hasTopbanner hasLeftbanner hasRightbanner hasBottombanner pagetype_default" lang="en">
<!--<![endif]-->
<head>
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<title>Getting Started - Mobile</title>
<meta name="description" content="MBMG">
<meta name="keywords" content="Montana Bureau of Mines and Geology">
<meta name="poweredby" content="finalsite.com">
<meta http-equiv="X-UA-Compatible" content="IE=Edge">
<meta http-equiv="Expires" content="0">
<meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
<script type="text/javascript">window.NREUM || (NREUM = {}), __nr_require = function (t, e, n) { function r(n) { if (!e) { var o = e = { exports: {} }; t[0].call(o.exports, function (e) { var o = t[1]; return r(o || e) }, o, o.exports) } return e.exports } if ("function" == typeof __nr_require) return __nr_require; for (var o = 0; o < n.length; o++) r(n); return r }({ 1: [function (t, e, n) { function r() { } function o(t, e, n) { return function () { return i(t, [(new Date).getTime()].concat(u(arguments)), e ? null : this, n), e ? void 0 : this } } var i = t("handle"), a = t(2), u = t(3), c = t("ee").get("tracer"), f = NREUM; "undefined" == typeof window.newrelic && (newrelic = f); var s = ["setPageViewName", "setCustomAttribute", "finished", "addToTrace", "inlineHit"], p = "api-", l = p + "ixn-"; a(s, function (t, e) { f = o(p + e, !0, "api") }), f.addPageAction = o(p + "addPageAction", !0), e.exports = newrelic, f.interaction = function () { return (new r).get() }; var d = r.prototype = { createTracer: function (t, e) { var n = {}, r = this, o = "function" == typeof e; return i(l + "tracer", [Date.now(), t, n], r), function () { if (c.emit((o ? "" : "no-") + "fn-start", [Date.now(), r, o], n), o) try { return e.apply(this, arguments) } finally { c.emit("fn-end", [Date.now()], n) } } } }; a("setName,setAttribute,save,ignore,onEnd,getContext,end,get".split(","), function (t, e) { d = o(l + e) }), newrelic.noticeError = function (t) { "string" == typeof t && (t = new Error(t)), i("err", [t, (new Date).getTime()]) } }, {}], 2: [function (t, e, n) { function r(t, e) { var n = [], r = "", i = 0; for (r in t) o.call(t, r) && (n = e(r, t), i += 1); return n } var o = Object.prototype.hasOwnProperty; e.exports = r }, {}], 3: [function (t, e, n) { function r(t, e, n) { e || (e = 0), "undefined" == typeof n && (n = t ? t.length : 0); for (var r = -1, o = n - e || 0, i = Array(o < 0 ? 0 : o) ; ++r < o;) i = t[e + r]; return i } e.exports = r }, {}], ee: [function (t, e, n) { function r() { } function o(t) { function e(t) { return t && t instanceof r ? t : t ? u(t, a, i) : i() } function n(n, r, o) { t && t(n, r, o); for (var i = e(o), a = l(n), u = a.length, c = 0; c < u; c++) a.apply(i, r); var s = f[m]; return s && s.push([w, n, r, i]), i } function p(t, e) { g = l(t).concat(e) } function l(t) { return g || [] } function d(t) { return s = s || o(n) } function v(t, e) { c(t, function (t, n) { e = e || "feature", m = e, e in f || (f = []) }) } var g = {}, m = {}, w = { on: p, emit: n, get: d, listeners: l, context: e, buffer: v }; return w } function i() { return new r } var a = "nr@context", u = t("gos"), c = t(2), f = {}, s = {}, p = e.exports = o(); p.backlog = f }, {}], gos: [function (t, e, n) { function r(t, e, n) { if (o.call(t, e)) return t; var r = n(); if (Object.defineProperty && Object.keys) try { return Object.defineProperty(t, e, { value: r, writable: !0, enumerable: !1 }), r } catch (i) { } return t = r, r } var o = Object.prototype.hasOwnProperty; e.exports = r }, {}], handle: [function (t, e, n) { function r(t, e, n, r) { o.buffer(, r), o.emit(t, e, n) } var o = t("ee").get("handle"); e.exports = r, r.ee = o }, {}], id: [function (t, e, n) { function r(t) { var e = typeof t; return !t || "object" !== e && "function" !== e ? -1 : t === window ? 0 : a(t, i, function () { return o++ }) } var o = 1, i = "nr@id", a = t("gos"); e.exports = r }, {}], loader: [function (t, e, n) { function r() { if (!h++) { var t = y.info = NREUM.info, e = s.getElementsByTagName("script")[0]; if (t && t.licenseKey && t.applicationID && e) { c(m, function (e, n) { t || (t = n) }); var n = "https" === g.split(":")[0] || t.sslForHttp; y.proto = n ? "https://" : "http://", u("mark", ["onload", a()], null, "api"); var r = s.createElement("script"); r.src = y.proto + t.agent, e.parentNode.insertBefore(r, e) } } } function o() { "complete" === s.readyState && i() } function i() { u("mark", ["domContent", a()], null, "api") } function a() { return (new Date).getTime() } var u = t("handle"), c = t(2), f = window, s = f.document, p = "addEventListener", l = "attachEvent", d = f.XMLHttpRequest, v = d && d.prototype; NREUM.o = { ST: setTimeout, CT: clearTimeout, XHR: d, REQ: f.Request, EV: f.Event, PR: f.Promise, MO: f.MutationObserver }, t(1); var g = "" + location, m = { beacon: "bam.nr-data.net", errorBeacon: "bam.nr-data.net", agent: "js-agent.newrelic.com/nr-963.min.js" }, w = d && v && v
&& !/CriOS/.test(navigator.userAgent), y = e.exports = { offset: a(), origin: g, features: {}, xhrWrappable: w }; s
? (s
("DOMContentLoaded", i, !1), f
("load", r, !1)) : (s("onreadystatechange", o), f("onload", r)), u("mark", ["firstbyte", a()], null, "api"); var h = 0 }, {}] }, {}, ["loader"]);</script>
<link rel="shortcut icon" href="http://mbmgweb.mtech.edu/newweb/favicon.ico">
<link rel="canonical" href="http://www.misericordia.edu/page.cfm?p=501">
<link rel="stylesheet" href="http://www.misericordia.edu/styles.cfm?b=1469446013869">
<link type="text/css" rel="stylesheet" href="http://mbmgweb.mtech.edu/newweb3/ss.css">
<style type="text/css">
body {
margin-top: 0px;
margin-right: 0;
margin-bottom: 0;
margin-left: 0px;
color: #;
font: 14px;
line-height: 150%;
table {
text-align: left;
a {
color: #;
a:visited {
color: #;
a:active {
color: #;
input {
font: 14px;
color: #;
select {
font: 14px;
textarea {
font: 14px;
color: #;
.buttons {
font: 14px;
color: white;
font-weight: bold;
background-color: #;
.text_misc, .text_misc td {
line-height: normal;
.text_misc p {
margin-top: 0px;
.hier {
font: 10px;
color: #;
#topbanner {
width: 100%;
margin-top: 0px;
margin-right: auto;
margin-left: auto;
padding-top: 0px;
padding-right: 0px;
padding-bottom: 0px;
padding-left: 0px;
#midcontainer {
#mainmiddle {
width: 100%;
min-height: 200px;
margin-top: 0px;
margin-right: auto;
margin-bottom: 0px;
margin-left: auto;
#contentdiv {
min-height: 200px;
height: 100%;
#bottomcontainer {
clear: both;
text-align: center;
#bottombanner {
width: 100%;
margin-top:;
margin-right: auto;
margin-bottom:;
margin-left: auto;
padding-top: 0px;
padding-right: 0;
padding-left: 0px;
#poweredby {
padding-top: 5px;
padding-bottom: 5px;
text-align: center;
#poweredby div {
width: 100%;
margin: auto;
</style>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/jquery.min.js"></script>
<script type="text/javascript"> var $j = jQuery.noConflict(); </script>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/fs_global.js"></script>
window.name = 'finalsite_misericordia';
var pageid = 501;
var pagearray = new Array();
pagearray[0] = 501;
trackingpath = '/Academics'; //Fix syntax highlighting "
</script>
<style type="text/css" media="screen">
#navtable_5 {
list-style-type: none;
margin: 0px 0px 0px 0px;
padding: 0;
#navtable_5 ul {
margin: 0;
padding: 0;
#navtable_5 a, #navtable_5 a:link, #navtable_5 a:visited {
display: block;
padding-top: 0px;
padding-right: 0px;
padding-left: 0px;
margin-bottom: 0px;
font-size: 13px;
text-decoration: none;
#navtable_5 span {
display: block;
background-image: none !important;
/* 2nd level */
#navtable_5 ul a {
background: none !important;
padding-left: 24px !important;
border-color: transparent !important;
font-size: 13px !important;
font-weight: normal !important;
#navtable_5 ul a span {
/* 3rd level */
#navtable_5 ul ul a {
padding-left: 36px !important;
#navtable_5 ul ul a span {
/* On State */
#navtable_5 a.navon {
#navtable_5 a.navon span {
/* Hover State */
#navtable_5 a:hover {
</style>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/plugins/jquery.fsBreakly.js"></script>
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/pages/blogs/blog.js"></script>
<link rel="stylesheet" type="text/css" href="http://newcss.finalsite.com/160724/css/news/news.css">
<link type="text/css" rel="stylesheet" href="http://newjs.finalsite.com/160724/javascript/jQuery/themes/finalsite/jquery.ui.1.8rc3.css">
<style type="text/css"></style>
#bannermod208 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod208, #bannermod208 td {
#bannermod208 .bannermodtitle {
#bannermod208 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod180 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod180, #bannermod180 td {
#bannermod180 .bannermodtitle {
#bannermod180 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod10 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod10, #bannermod10 td {
#bannermod10 .bannermodtitle {
#bannermod10 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod334 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod334, #bannermod334 td {
#bannermod334 .bannermodtitle {
#bannermod334 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod182 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod182, #bannermod182 td {
#bannermod182 .bannermodtitle {
#bannermod182 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#leftbanner {
width: 208px;
#bannermod5 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod5, #bannermod5 td {
#bannermod5 .bannermodtitle {
#bannermod5 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#rightbanner {
width: 220px;
#bannermod262 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod262, #bannermod262 td {
#bannermod262 .bannermodtitle {
#bannermod262 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#rightbanner {
width: 220px;
#bannermod207 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod207, #bannermod207 td {
#bannermod207 .bannermodtitle {
#bannermod207 .bannermodtd {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod224 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod224, #bannermod224 td {
#bannermod224 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod224 .bannermodtitle {
#bannermod184 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod184, #bannermod184 td {
#bannermod184 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod184 .bannermodtitle {
#bannermod191 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod191, #bannermod191 td {
#bannermod191 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod191 .bannermodtitle {
#bannermod193 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod193, #bannermod193 td {
#bannermod193 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod193 .bannermodtitle {
#bannermod194 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod194, #bannermod194 td {
#bannermod194 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod194 .bannermodtitle {
#bannermod195 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod195, #bannermod195 td {
#bannermod195 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod195 .bannermodtitle {
#bannermod196 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod196, #bannermod196 td {
#bannermod196 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod196 .bannermodtitle {
#bannermod197 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod197, #bannermod197 td {
#bannermod197 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod197 .bannermodtitle {
#bannermod192 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod192, #bannermod192 td {
#bannermod192 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod192 .bannermodtitle {
#bannermod185 {
margin-left: 0px;
margin-right: 0px;
margin-top: 0px;
margin-bottom: 0px;
#bannermod185, #bannermod185 td {
#bannermod185 .bannermodcontent {
padding-left: 0px;
padding-right: 0px;
padding-top: 0px;
#bannermod185 .bannermodtitle {
</style>
<!-- BROWSER VIEWPORT -->
<meta name="viewport" content="initial-scale=1, width=device-width" />
<!-- CORE STYLESHEETS -->
<link href="http://mbmgweb.mtech.edu/newweb3/core.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/layout.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-desktop.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-tablet.css" rel="stylesheet" type="text/css">
<link href="http://mbmgweb.mtech.edu/newweb3/core-mobile.css" rel="stylesheet" type="text/css">
<!-- CUSTOM STYLESHEET -->
<link href="http://mbmgweb.mtech.edu/newweb3/custom.css?604" rel="stylesheet" type="text/css">
<link href="http://www.misericordia.edu/uploaded/code/revisions.css?527" rel="stylesheet" type="text/css">
<!-- LIBRARY CSS -->
<link href="http://maxcdn.bootstrapcdn.com/font-awesome/4.2.0/css/font-awesome.min.css" rel="stylesheet">
<link rel="stylesheet" href="http://www.misericordia.edu/uploaded/template/code/jquery.mCustomScrollbar.css" />
<!-- IE RELATED FIXES -->
<!--[if lte IE 8]>
<link href="uploaded/template/code/ie-fix.css" rel="stylesheet">
<link href="uploaded/template/code/ie-news.css" rel="stylesheet">
<script src="uploaded/code/css3-mediaqueries.js" type="text/javascript" language="javascript"></script>
<![endif]-->
<!-- JQUERY PLUGINS & SNIPPETS -->
<script src="http://www.misericordia.edu/uploaded/code/jquery.flexslider.js"></script>
<script src="http://malihu.github.io/custom-scrollbar/jquery.mCustomScrollbar.concat.min.js"></script>
<!-- LOCALIZED SCRIPTS -->
<script src="http://www.misericordia.edu/uploaded/template/code/jquery.core.js?v=2"></script>
<!-- INSERT TYPEKITS OR GOOGLE FONTS -->
<link href='http://fonts.googleapis.com/css?family=Source+Sans+Pro:400,600,700,700italic,600italic,400italic,300...' rel='stylesheet' type='text/css'>
<script>
(function (i, s, o, g, r, a, m) {
i['GoogleAnalyticsObject'] = r; i = i || function () {
(i.q = i.q || []).push(arguments)
}, i.l = 1 * new Date(); a = s.createElement(o),
m = s.getElementsByTagName(o)[0]; a.async = 1; a.src = g; m.parentNode.insertBefore(a, m)
})(window, document, 'script', '//www.google-analytics.com/analytics.js', 'ga');
ga('create', 'UA-3000352-1', 'auto');
ga('send', 'pageview');
</script>
<!-- Start of Async HubSpot Analytics Code -->
(function (d, s, i, r) {
if (d.getElementById(i)) { return; }
var n = d.createElement(s), e = d.getElementsByTagName(s)[0];
n.id = i; n.src = '//js.hs-analytics.net/analytics/' + (Math.ceil(new Date() / r) * r) + '/536549.js';
e.parentNode.insertBefore(n, e);
})(document, "script", "hs-analytics", 300000);
</script>
<!-- End of Async HubSpot Analytics Code -->
<!-- Go to www.addthis.com/dashboard to customize your tools -->
<script type="text/javascript" src="//s7.addthis.com/js/300/addthis_widget.js#pubid=ra-54be8237215169f8" async="async"></script>
<!-- begin CBE code -->
<script>
(function (a, b, c, d, e, f, g) {
a = a || function () { (a.q = a.q || []).push(arguments) }; f = b.createElement(c);
g = b.getElementsByTagName(c)[0]; f.async = 1; f.src = d + "/cbe/"; g.parentNode.insertBefore(f, g);
a('create', d, 2);
a('log', 'pageview');
})(window, document, "script", "https://mis.capturehighered.net", "_cbe");
</script>
<!-- end CBE code -->
<!-- Siteimprove code -->
<script>
(function () {
var sz = document.createElement('script'); sz.type = 'text/javascript'; sz.async = true;
sz.src = '//us1.siteimprove.com/js/siteanalyze_54160.js';
var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(sz, s);
</script>
<!-- End of Siteimprove code -->
<!-- Support -->
<link href="http://mbmgweb.mtech.edu/newweb3/support.custom.css?542016" rel="stylesheet" type="text/css">
<script src="http://www.misericordia.edu/uploaded/themes/library/js/support.custom.js"></script>
<!-- Bootstrap core CSS
<link href="http://mbmgweb.mtech.edu/newweb3/bootstrap.min.css" rel="stylesheet">-->
<!-- IE10 viewport hack for Surface/desktop Windows 8 bug -->
<link href="https://getbootstrap.com/assets/css/ie10-viewport-bug-workaround.css" rel="stylesheet">
<!-- Custom styles for this template -->
<link href="http://mbmgweb.mtech.edu/newweb3/signin.css" rel="stylesheet">
<!-- Just for debugging purposes. Don't actually copy these 2 lines! -->
<!--[if lt IE 9]><script src="../../assets/js/ie8-responsive-file-warning.js"></script><![endif]-->
<script src="https://getbootstrap.com/assets/js/ie-emulation-modes-warning.js"></script>
<!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/html5shiv/3.7.3/html5shiv.min.js"></script>
<script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18esri/css/esri.css" />
<link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://data.mbmg.mtech.edu/css/mapperStyles_1.css">
<script type="text/javascript" src="http://js.arcgis.com/3.13/"></script>
<script type="text/javascript" src="http://mbmgweb.mtech.edu/3.13/mapper/js/productionQuakesView313.js"></script>
<link rel="stylesheet" href="https://developers.arcgis.com/javascript/3/samples/mobile_template/css/main.css">
#HomeButton {
position: absolute;
top: 95px;
left: 20px;
z-index: 50;
</style>
</head>
<body class="yui-skin-sam" onload="try{pageLoad()}catch(err){};try{loadmap()}catch(err){}">
<div id="bodydiv" class="text">
<!-- Start Top Banner -->
<div id="topcontainer">
<div id="topbanner">
<div id="bannermod208" class="top-nav-slide mobile">
<div id="bannerdiv208" class="bannermodcontent">
<div style="clear: both;"><!-- --></div>
<div id="content208">
<button type="button" id="mobile-nav-close">Close</button>
<form method="get" action="searchresults.cfm" name="fs_search">
<input name="keywords" placeholder="search mbmg" id="search_keywords" type="text">
<label for="search_keywords">Search Keywords</label>
<button type="submit" id="search_submit"><i class="fa fa-search"></i>Search</button>
</form>
<ul class="nav-m-main"></ul>
<ul class="nav-m-quick"></ul>
</div>
</div>
</div>
<div id="bannermod180" class="header-logo row">
<div id="bannerdiv180" class="bannermodcontent">
<div id="content180">
<!-- LOGO -->
<a href="page.cfm?p=1" class="site-logo"><img src="http://mbmgweb.mtech.edu/newweb3/logombmg.png" alt="Clicking the Misericordia University logo will return you to the homepage"></a>
<!-- END LOGO -->
<!-- SEARCH BAR -->
<input name="keywords" id="search_keywords_mobile" placeholder="search mbmg" type="text">
<label for="search_keywords_mobile">Search Keywords</label>
</form>
<!-- END SEARCH -->
<!-- HEADER NAV -->
<ul>
<li><a href="#">Home</a></li>
<li><a href="#">Well Data</a></li>
<li><a href="#">Reports</a></li>
<li><a href="#">DrillerWeb</a></li>
<li><a href="#">DNRC</a></li>
<li><a href="#">Help!</a></li>
</ul>
<!-- END HEADER NAV -->
<!-- MOBILE NAV TRIGGER -->
<button id="mobile-nav-control" class="mobile" type="button"><i class="fa fa-navicon"></i> Menu</button>
<!-- END MOBILE NAV TRIGGER -->
</div>
</div>
</div>
<div id="bannermod10" class="main-nav">
<div id="bannerdiv10" class="bannermodcontent">
<div id="content10">
<ul id="nav" class="row">
<li><a href="https://community.esri.com/Final_v1/main.html" target="_self" class="fsBtn">Home</a></li>
<li><a href="https://community.esri.com/Final_v1/about/about-mbmg.html?p=499" target="_self" class="fsBtn">About</a></li>
<li><a href="../newweb3/page.cfm?p=503" class="fsBtn">Research</a></li>
<li><a href="../newweb3/page.cfm?p=505" class="fsBtn">Information</a></li>
<li><a href="https://community.esri.com/Final_v1/museum/museum-main.html?p=504" target="_self" class="fsBtn">Mineral Museum</a></li>
<li><a href="../newweb3/njf/page.cfm?p=506" class="fsBtn">Kids</a></li>
</ul>
</div>
</div>
</div>
</div>
</div>
<div id="bannermod334" class="print-page">
<div id="bannerdiv334" class="bannermodcontent">
<!-- <div id="content334"><span id="print-page"><a href="#" title="print page" onclick="printpage(); return false;"><img src="http://www.misericordia.edu/images/admin_ui/2.0/black/print.png" alt="print calendar" border="0"></a></span></div>-->
</div>
</div>
<!--<div id="bannermod182" class="hier-tools hidden">
<div id="bannerdiv182" class="bannermodcontent">
<div style="clear: both;"></div>
<div id="content182">
<div class="hiersect"><a href="page.cfm?p=1">Home</a> &gt; <div class=hier style='margin-left: 0'>Information</div>
</div>
</div>
</div>-->
</div><!-- end topbanner-->
</div><!-- End topcontainer -->
<!-- Begin middle section -->
<div id="midcontainer">
<div id="mapView" data-dojo-type="dojox.mobile.View" data-dojo-props="selected: true">
<div id="mapContainer" data-dojo-type="dojox.mobile.ContentPane">
<div id="map"></div>
</div>
</div>
</div>
<!-- end of midcontainer -->
<!-- begin bottombanner-->
<!-- end bottombanner -->
<!-- end bottomcontainer -->
</div> <!-- end of body -->
<div id="nav_menus" style="position:absolute; top:0; left:0;">
<div id="dhtmlmenu_499" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_499',this.id);">
<ul>
<li>
<a href="page.cfm?p=518">Staff Information</a>
</li>
<li>
<a href="page.cfm?p=565">Location</a>
</li>
<li>
<a href="page.cfm?p=516">Director's Message</a>
</li>
<li>
<a href="page.cfm?p=515">Current Jobs</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_500" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_500',this.id);">
<ul>
<li>
<a href="http://misericordia.edu/page.cfm?p=986" target="_blank">MU Today</a>
</li>
<li>
<a href="http://www.misericordia.edu/page.cfm?p=779" target="_blank">Publications</a>
</li>
<li>
<a href="page.cfm?p=520">Campus Calendar</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_501" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_501',this.id);">
<ul>
<li>
<a href="http://misericordia.edu/page.cfm?p=540" target="_blank">Apply Now</a>
</li>
<li>
<a href="page.cfm?p=530">Majors and Programs</a>
</li>
<li>
<a href="page.cfm?p=709">Academic Colleges</a>
</li>
<li>
<a href="page.cfm?p=710">University Catalog</a>
</li>
<li>
<a href="page.cfm?p=524">Course Schedule</a>
</li>
<li>
<a href="page.cfm?p=712">Honors Program</a>
</li>
<li>
<a href="page.cfm?p=713">Vice President of Academic Affairs</a>
</li>
<li>
<a href="page.cfm?p=714">Office of Service-Learning</a>
</li>
<li>
<a href="page.cfm?p=523">Registrar</a>
</li>
<li>
<a href="page.cfm?p=1476">Academic Calendars</a>
</li>
<li>
<a href="http://library.misericordia.edu">Library</a>
</li>
<li>
<a href="page.cfm?p=1371">Commencement</a>
</li>
<li>
<a href="http://studyabroad-away.misericordia.edu/">Study Abroad/Study Away</a>
</li>
</ul>
</div>
</div>-->
<div id="dhtmlmenu_503" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_503',this.id);">
<ul>
<li>
<a href="http://athletics.misericordia.edu/" target="_blank">GWIC</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/staff.aspx" target="_blank">SWAMP</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/hof.aspx?type=class_induction#" target="_blank">GWIP</a>
</li>
<li>
<a href="http://athletics.misericordia.edu/sports/2012/9/17/AthFac_0917120421.aspx" target="_blank">GWAP</a>
</li>
</ul>
</div>
<div id="dhtmlmenu_505" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_503',this.id);">
<ul>
<li>
<a href="http://athletics.misericordia.edu/" target="_blank">Mining Program</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">Geologic Research and Mapping</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">State Geology Map</a>
</li>
<li>
<a href="http://www.mucougarsgear.com/" target="_blank">GIS</a>
</li>
</ul>
</div>
<!-- <div id="dhtmlmenu_504" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_504',this.id);">
</div>-->
<div id="dhtmlmenu_506" style="visibility:hidden;" onmouseover="clearTimeout(wait);" onmouseout="mnuOut('dhtmlbtn_506',this.id);">
<ul>
<li>
<a href="http://cougarconnect.misericordia.edu/s/352/index.aspx?sid=352&gid=1&pgid=938" target="_blank">Science fair</a>
</li>
</ul>
</div>
<!-- Quick Links Setup -->
<div id="ql_menu" onmouseover="fsBtn('ql_btn');" onmouseout="fsBtn('ql_btn','off');" style="visibility: hidden;">
<ul><li><a href="https://mymu.misericordia.edu" target="_blank">Home</a></li><li><a href="https://mymu.misericordia.edu" target="_blank">WellData</a></li><li><a href="http://cougarconnect.misericordia.edu" target="_blank">Reports</a></li><li><a href="page.cfm?p=557" target="_self">DrillerWeb</a></li><li><a href="page.cfm?p=557" target="_self">DrillerWeb</a></li><li><a href="page.cfm?p=557" target="_self">DNRC</a></li></ul>
</div>
<!-- End Quick Links Setup -->
<script type="text/javascript" src="http://newjs.finalsite.com/160724/javascript/jQuery/jquery.ui.min.js"></script>
var relativeBasePath = '';
var siteurl = 'http://www.misericordia.edu';
var siteSSLurl = 'https://www.misericordia.edu';
var baseurl = '';
</script>
<script type="text/javascript">window.NREUM || (NREUM = {}); NREUM.info = { "errorBeacon": "bam.nr-data.net", "licenseKey": "17f1641df3", "agent": "", "beacon": "bam.nr-data.net", "applicationTime": 510, "applicationID": "3347190,3347007,1110036", "transactionName": "b1wDZ0dSXBUFBRZZC1YWIkZGR10LSxYDVwEWWgdeGkBGBwoCA0IA", "queueTime": 0 }</script>
</body>
</html>
Bulbul,
  OK, I am a little confused then. You mention you are having issue with a dojox mobile view  and the productionWellsView313.js does not have any dojox requires in it?...
BulbulMajumder1
New Contributor III
The attached html contains the following snippet
without using dojox requires in productionWellsView313.js
The html shows this page. Only clicking on span, the map is being displayed.
I would like to get the map on-screen and use spans to navigate the map.
Now, if I include the dojox requires in productionWellsView313.js, the page becomes completely empty.
Please help. I hope this will make sense , if not let me know.
Bulbul
BulbulMajumder1
New Contributor III
So this make any sense Robert ?
