Attribute Table Error Message
973
6
11-21-2016 12:41 PM
AntoineBartholomew
New Contributor III
Has anyone seen this error when using the attribute table?  The error message reads:
Data not available
Click [Refresh] button to try again
deleted-user-CQZbjNeBXm49
Occasional Contributor III
Antoine,
No I haven't but I had recommend you take proper look at the underlying data source (Table) first, and also what server (ArcGIS Online or ArcGIS Server) are you using?
Baba
AntoineBartholomew
New Contributor III
Thanks for the reply Baba,
I am confused because I am working with a service that has several sub layers.  Layers 0 and 2 work just fine within the attribute table, while the others give me the error message.  These services are hosted on ArcGIS server v 10.2.  I am pulling in the feature services into the map using the operational layers structure, with out using a web map.
Hi Antoine,
I have had this same issue before, and all I did was to go back my mxd doc, check that the tables and fields were fine, then re-published the map service, did a browser base (MapServer/1/query) query to validate, then re-add the feature service.
NB: On the side what do you mean by " using the operational layers structure, with out using a web map"?
Baba
AntoineBartholomew
New Contributor III
Thanks for the reply.  I am not sure that re-publishing the services is the solution.  I say this because, I am able to use the attribute table on the same feature services hosted within the GIS-Portal, but when I build out the web app using the same feature services outside of the portal (using operational layers), I receive the Data not available, Click Refresh button to try again error.  I just can not understand why the attribute table works with some feature layers (0,2) and not all the layers...
Side Note:
Operational Layers - are used to pull in the same info hosted within a web map, but without using a web map.  See the following code snippet:
 "map": {
        "3D": false,
        "2D": true,
        "position": {
            "left": 325,
            "top": 40,
            "right": 0,
            "bottom": 0
        "id": "map",
        "itemId": {
            "item": {
                "title": "Translink Map Service gisapd01 webmap",
                "type": "Web Map",
                "description": null,
                "tags": [
                    "translink"
                "snippet": "Translink Map Service gisapd01 webmap",
                "thumbnail": null,
                "documentation": null,
                "extent": [
                        -123.309,
                        49.0408
                        -122.5509,
                        49.3567
                "spatialReference": null,
                "accessInformation": null,
                "licenseInfo": null,
                "culture": "en-us"
            "itemData": {
                "operationalLayers": [
                        "id": "ViewerBusStop_8025",
                        "layerType": "ArcGISMapServiceLayer",
                        "url": "http://gisapd01.translink.bc.ca/cmbc/rest/services/BusStop/ViewerBusStop/MapServer",
                        "visibility": true,
                        "visibleLayers": [
                            0,
                            6,
                            7
                        "opacity": 1,
                        "title": "Bus Stop Viewer",
                        "layers": [
                                "id": 6,
                                "popupInfo": {
                                    "title": "Bus Route: {LINEABBR}",
                                    "fieldInfos": [
                                            "fieldName": "OBJECTID",
                                            "label": "OBJECTID",
                                            "tooltip": "",
                                            "visible": false,
                                            "stringFieldOption": "textbox"
                                            "fieldName": "SERVICE",
                                            "label": "Service",
                                            "tooltip": "",
                                            "visible": true,
                                            "format": {
                                                "places": 0,
                                                "digitSeparator": true
                                    "showAttachments": true,
                                    "mediaInfos": [ ]
AntoineBartholomew
New Contributor III
ArcGIS web map JSON format
The link above details how I worked with WAB with out a web map.  Babatope.Adebajo@hertfordshire.gov.uk_hertscc
Thanks Antoine,
I hope you found a solution to the attribute error?.
Baba
