ExportImage method not found in Swift 3.0
2191
6
11-22-2016 06:39 AM
JayMehta
Hello Team ,
Xcode : 8.0
Swift : 3.0
I am not able to find "exportImage" method ,
i am not getting the method in intelli-sense of xcode
self.mapView.exportImage { [weak self] (image:UIImage?, error:NSError?) -> Void in
           if error != nil{
               UIAlertView(title: "Error", message: error.localizedDescription, delegate: nil, cancelButtonTitle: "Ok").show()
           if let image = image {
               //on completion imitate flash
//                self?.imitateFlash(image)
did import any thing in file i import only ArcGIS?
let me know your suggestion.
Tags (3)
RyanOlson1
try this code for swift 3
        mapView.exportImage { (image, error) in
            if let error = error{
                print("error: \(error)")
            else if let image = image{
                print("image exported!")
this for swift 2.3:
        self.mapView?.exportImageWithCompletion({ (image, error) in
            if let error = error {
                print("success!")
JayMehta
We have already try this method in swift 3.0 but it is not working. Let me know alternative solution
Here below i have attached screen shots of that method
  "mapView.exportImage { (image, error) in"
RyanOlson1
Is your project settings set to use swift 3.0 or swift 2.3?
JayMehta
Hi
Project setting use swift 3.0
We have used xcode 8.0
YueWu1
by Esri Regular Contributor
Hi Jay,
Make sure to re-wire our framework and import a new ArcGIS Bundle in Xcode based on our doc:
Install and set up—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
$(HOME)/Library/SDKs/ArcGIS/iOS/Frameworks/Static
RyanOlson1
The only thing I can think of is that you are somehow referencing an old version of the sdk. Have you followed the steps in the documentation for setting up your project with the 100.0.0 version of the framework?
