Exception using wcf service in Android 6.0.1 version in QT/QML
1423
11-25-2016 04:46 AM
tanerkoka1
We are using Arcgis Runtime SDK for Qt 10.2.6 and Qt 5.4.2 (MSVC 2013, 32 bit) Qt Creator QT\QML side. And we are develop and deploy Adroid app with Android Armeobi-v7a (GCC4.9 , QT 5.4.2) kid.
We have Galaxy Tab 2 and our application is correct working (wcf login services) in Android Operating System 5.0.2 Version but when I update My Android OS to 6.0.1 and then when I tried to use wcf (login) services gives exception .How can I solve this important problem ?
We are using below code (in Main) for passing certificate:
QSslConfiguration config = QSslConfiguration::defaultConfiguration();
config.setPeerVerifyMode(QSslSocket::VerifyNone);
QSslConfiguration::setDefaultConfiguration(config);
Here is also our exception console output below;
D MenuDenemeNumarataj: (null):0 ((null)): int main(int, char**) ApplicationWindow_QMLTYPE_165_QML_191(0x9bbe2460)
D mali_winsys: new_window_surface returns 0x3000, [1536x2000]-format:1
D libGLESv2: DTS_GLAPI : DTS is not allowed for Package : com.mycompany.myappname
D ViewRootImpl: ViewPostImeInputStage processPointer 0
D ViewRootImpl: ViewPostImeInputStage processPointer 1
F libc : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x8 in tid 20871 (QtThread)
How Can I solve this problem ?
Best Regards
LucasDanzinger
Esri Frequent Contributor
This question would probably be better suited for the Qt forums - Home | Qt Forum
tanerkoka1
Hi Lucas ,
We are find how to solve  OpenSSL if running into errors from Android 6: http://doc.qt.io/qt-5/opensslsupport.html in this link from QT Forum but we can't solve in Windows OS.
Are there any source example to solve in Windows OS this problem ?
We are using Arcgis Runtime SDK for Qt 10.2.6 and Qt 5.4.2 (MSVC 2013, 32 bit) Qt Creator QT\QML side. And we are develop and deploy Adroid app with **Android Armeobi-v7a (GCC4.9 , QT 5.4.2) ** kid on Windows Operating System. So this is important problem with us .Can you get help from your QT team ? Or can I sent my app to solve this OpenSSL problem in Windows then sent to me correcy app wich works without errors because I can not solve in Windows side ?
Beste Regards
