Visual Studio 2013, WPF application, cannot view WebView control in the designer
2041
6
11-25-2016 06:26 PM
CharlesRoberts1
New Contributor III
ArcGIS SDK 100.0 .NET WPF
I only see "Cannot create an instance of MapView" in the designer, but the application does run, and the MapView control works as expected. I've tried uninstalling the extension and re-installing but no luck. I get the same result on Windows 10 and Windows 7 machines. Has no one else seen this?
PreetiMaske
We are unable to reproduce this. Usually that error is displayed until nuget packages are restored. Once the packages are restored and application is clean+rebuild, that error warning goes away.
CharlesRoberts1
New Contributor III
Update:
I noticed the client32 and client64 folders no longer come with the VCRuntime14 binaries. I did run the Windows 10 Universal Runtime update, but had not noticed it failed.
Including the VCRuntime binaries fixes the problem.
What should the subfolders of the ArcGISRuntime100.0 be named? Mine show up as:
client32
client64
resources
But I still get an issue with not being able to find the native DLL. Do they need to be x64, x86? I installed the 4.5.2 targeting pack.
PreetiMaske
You might be missing another requirement as listed in systems requirement
"Applications built with ArcGIS Runtime SDK for .NET require installation of Microsoft Visual C++ 2015 Redistributable Update 3."
https://developers.arcgis.com/net/latest/wpf/guide/system-requirements.htm
CharlesRoberts1
New Contributor III
Preeti ,
I did install the VC 2015 redist, but only 64-bit. Installing the 32 bit as well cleared it all up.
Charles
PreetiMaske
Glad it worked. It would make sense that installing x32 resolved the issue because by default a WPF Application has prefer 32 bit checked on and app needed 32 bit redistributable which was missing earlier.
PreetiMaske
Since VS is still a 32-bit process too, therefore it would be trying to load the 32-bit runtime.
