Failed to paste....The domain was not found
1402
11-28-2016 09:27 AM
chadh
Hello I am trying to make a backup copy of my File Geodatabase (Version 10.3, Windows 7). I have done this several times in the past but this time it is not allowing me to make the back as I get the following message:
"Failed to paste database XYZ The domain was not found"
I saw a post about this about 2 years ago but it seemed to never be resolved, does anyone know the cause of this error and/or a solution?
*I posted an attachment of the error I am receiving.
ModyBuchbinder
When you copy & paste it should copy any domains too. You should see all the elements that will be copied before the operation.
Are you copy to a clean FGDB - if not it might have some other domain with the same name.
Does this domain have any problems (try to export it to table).
Have Fun
Ahmed_AltafTambe
New Contributor III
Please do check the sdedc_SQLServer or sdedc_Oracle log file (in the following location on the ArcGIS client machine: C:\Users\User_Profile\AppData\Local\Temp ) and confirm if any FeatureClass name/Domain name is mentioned in the file, on the date_time when the error was encountered on the ArcGIS client machine and confirm if that domain does exist or not in the geodatabase .
Also you could  try and run the script in the following web-link to check the domain usage:
