How to Display Two Pie Charts in a Tabcontainer?
1594
11-28-2016 07:08 AM
SarojThapa1
Occasional Contributor III
I have two tabs on my Info Window Popup. My code is based on the sample ArcGIS API for JavaScript Sandbox. The only change compared to this sample is: I want to display pie charts on both the tabs. The issue I am facing is: The tab1 is selected when the popup appears but its content is not displayed. But if I click the tab2, the content (pie chart) is displayed. If I click the tab1 after I click the tab2, the pie chart in tab1 is displayed at this time. I am trying to get the pie chart displayed in tab1 when the user clicks the feature layer on the map. How can I fix the issue? Somebody please help me out with this.
<!DOCTYPE html>
<html>
<head>
    <title>Pie Chart</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
    <style>
        html, body, #map {
            height: 100%;
            width: 100%;
            margin: 0;
            padding: 0;
        .chart {
            width:200px;
            height:200px;
            padding:0 !important;
    </style>
    <script src="https://js.arcgis.com/3.18/"></script>
    <script>
        var map;
        // Try other themes: Julie, CubanShirts, PrimaryColors, Charged, BlueDusk, Bahamation, Harmony, Shrooms, Minty, Tom
        var theme = "PrimaryColors";
        require([
            "esri/map", "esri/layers/FeatureLayer",
            "esri/dijit/InfoWindow", "esri/InfoTemplate", "esri/dijit/Popup",
            "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
            "dijit/layout/ContentPane", "dijit/layout/TabContainer",
            "dojox/charting/Chart2D", "dojox/charting/plot2d/Pie",
            "dojox/charting/action2d/Highlight", "dojox/charting/action2d/MoveSlice", "dojox/charting/action2d/Tooltip",
            "dojox/charting/themes/" + theme,
            "dojo/dom-construct", "dojo/dom-class",
            "dojo/number", "dojo/parser","dojo/domReady!"
        ], function(
                Map, FeatureLayer,
                InfoWindow, InfoTemplate, Popup,
                SimpleFillSymbol, SimpleRenderer,
                ContentPane, TabContainer,
                Chart2D, Pie,
                Highlight, MoveSlice, Tooltip,
                dojoxTheme,
                domConstruct, domClass,
                number, parser
            parser.parse();
            // Use the info window instead of the popup.
            var infoWindow = new InfoWindow(null, domConstruct.create("div"));
            infoWindow.startup();
            map = new Map("map", {
                basemap: "topo",
                center: [-113.405, 43.521],
                infoWindow: infoWindow,
                zoom: 5
            map.infoWindow.resize(275, 275);
            var template = new esri.InfoTemplate();
            template.setTitle("<b>${Instl_Name}</b>");
            template.setContent(getWindowContent);
            var layer = new FeatureLayer("RESTUrlEndpoints/FeatureServer/0", {
                mode: FeatureLayer.MODE_ONDEMAND,
                infoTemplate: template,
                outFields: ["*"]
            map.addLayer(layer);
            function getWindowContent(graphic) {
                // Make a tab container.
                var tc = new TabContainer({
                    style: "width:100%;height:100%;"
                }, domConstruct.create("div"));
                // Display 1st pie chart.
                var cp1 = new ContentPane({
                    title: "Collection"
                tc.addChild(cp1);
                var c1 = domConstruct.create("div",{
                var chart1 = new Chart2D(c1);
                domClass.add(chart1, "chart1");
                chart1.setTheme(dojoxTheme);
                chart1.addPlot("default", {
                    type: "Pie",
                    radius: 70,
                    htmlLabels: true
                tc.watch("selectedChildWidget", function(name, oldVal, newVal) {
                    if (newVal.title === "Collection") {
                        chart1.resize(180, 180);
                // Calculate percent complete/ incomplete.
                var total1 = 100;
                var complete_collection = number.round(graphic.attributes.Data_Collection);
                var incomplete_collection = total1 - complete_collection;
                chart1.addSeries("% Complete", [{
                    y: incomplete_collection,
                    tooltip: incomplete_collection,
                    text: "% Incomplete",
                    color: "red"
                    y: complete_collection,
                    tooltip: complete_collection,
                    text: "% Complete",
                    color: "green"
                //highlight the chart and display tooltips when you mouse over a slice.
                new Highlight(chart1, "default");
                new Tooltip(chart1, "default");
                new MoveSlice(chart1, "default");
                cp1.set("content", chart1.node);
                // Display a dojo pie chart for the complete/incomplete percentage.
                var cp2 = new ContentPane({
                    title: "Processing"
                tc.addChild(cp2);
                // Create the chart that will display in the second tab.
                var c = domConstruct.create("div", {
                var chart = new Chart2D(c);
                domClass.add(chart, "chart");
                // Apply a color theme to the chart.
                chart.setTheme(dojoxTheme);
                chart.addPlot("default", {
                    type: "Pie",
                    radius: 70,
                    htmlLabels: true
                    if (newVal.title === "Processing") {
                        chart.resize(180, 180);
                var total = 100;
                var complete_processing = number.round(graphic.attributes.Data_Development);
                var incomplete = total - complete_processing;
                chart.addSeries("% Complete", [{
                    y: incomplete,
                    tooltip: incomplete,
                    color: "red"
                    y: complete_processing,
                    tooltip: complete_processing,
                    text: "% Complete",
                    color: "green"
                new Highlight(chart, "default");
                new Tooltip(chart, "default");
                new MoveSlice(chart, "default");
                // cp1.set("content", chart.node);
                cp2.set("content", chart.node);
                return tc.domNode;
    </script>
</head>
<body class="claro">
<div id="map"></div>
</body>
</html>
