Trouble creating custom services
1415
5
11-30-2016 12:30 PM
CynthiaKozma
Occasional Contributor II
I have been trying to publish both a Geoprocessing Service (a buffer tool) and a printing service to use in a Web AppBuilder Developer app hosted on our local server.  After going through the process, although they show up in the Services Directory, neither has a task.  I am creating both through the Results Window of ArcGIS 10.4 and our ArcGIS Server that they are sitting on is 10.2.2.  This is the first time trying to host a web app on a local machine, so this is all new to me.  Is the difference in versions the problem or am I missing something else.  Any help would be appreciated!
JonathanQuinn
Esri Notable Contributor
I suggest the first thing to try is to try to publish with ArcMap 10.2.2.  There are likely problems publishing from ArcMap to Server when the versions are different.
CynthiaKozma
Thank you so much!  I was thinking that I may have it in the wrong category.
JonathanQuinn
CynthiaKozma
Thank you!  I will see if I can find a machine with 10.2.2 on it!
CynthiaKozma
We went ahead and upgraded Server to 10.4.  No problems now, so versions do have to be the same.
