I am trying create toggle bottom div, but center div does not updates its size. What is wron?
When I resize browser window, all divs became right size.
<!DOCTYPE html>
<html>
<head>
<title>Example</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.18/esri/css/esri.css">
<style>
html,
body {
height: 100%;
width: 100%;
margin: 0%;}
</style>
<script src="http://js.arcgis.com/3.18/init.js"></script>
<script>
require(["esri/map", "esri/dijit/Basemap", "dojo/parser"], function(
Map, Basemap, parser
parser.parse();
map = new Map("map", {
basemap: "osm",
center: [37.6,55.7],
zoom: 8,
function toggle_visibility(id) {
var e = document.getElementById(id);
var s = document.getElementById(id+'_splitter');
if(e.style.display == 'none'){
if (s){
s.style.display = 'block';
e.style.display = 'block';
} else {
if (s){
s.style.display = 'none';
e.style.display = 'none';
</script>
</head>
<body class="claro">
<div id="contentAll" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'center'" style="width: 100%; height: 100%; margin: 0;">
<div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'center'" style="width: 100%; height: 100%; margin: 0;">
<div id="navToolbar" data-dojo-type="dijit/Toolbar" data-dojo-props="region:'top'" >
<div data-dojo-type="dijit/form/Button" id="tableButton" data-dojo-props="onClick: function(){toggle_visibility('bott')}">Show/Hide bottom table</div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden">
</div>
</div>
<div id="bott" data-dojo-type="dijit/layout/ContentPane" data-dojo-props='region:"bottom", splitter:true, style:"height:150px"'>
</div>
</div>
</body>
</html>
Solved! Go to Solution.
Leonid,
You have to work with BorderContainer differently:
<!DOCTYPE html>
<html>
<head>
<style>
html,
body {
height: 100%;
width: 100%;
margin: 0%;}
</style>
<script>
require([
"dijit/registry", "dojo/on", "dojo/dom", "dojo/parser",
"dijit/form/Button", "dijit/Toolbar", "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, Basemap, registry, on, dom, parser
parser.parse();
basemap: "osm",
zoom: 8,
on(dom.byId("tableButton"), "click", function(){
toggle_visibility("bott");
function toggle_visibility() {
var appLayout = registry.byId("contentAll");
var bottPanel = registry.byId("bott");
var panelIndex = appLayout.getIndexOfChild(bottPanel);
if(panelIndex >= 0) {
appLayout.removeChild(bottPanel);
} else {
appLayout.addChild(bottPanel);
appLayout.resize();
</script>
</head>
<div data-dojo-type="dijit/form/Button" id="tableButton">Show/Hide bottom table</div>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
Remove the onClick event from the prop attribute of the button and specify it as a seperate attribute:
<div data-dojo-type="dijit/form/Button" id="tableButton" onClick="toggle_visibility('bott')">Show/Hide bottom table</div>
Also place your "bott " element within the "content" div.
Then change your toggle_visibility function to resize the map div (assuming that is what you want to happen):
var s = document.getElementById(id + '_splitter');
var m = document.getElementById('map');
if (e.style.display == 'none') {
if (s) {
m.style.height = document.body.scrollHeight -240 + 'px'
} else {
if (s) {
m.style.height = document.body.scrollHeight - 70 + 'px'
Unfortunately it does't work correctly: after clicking on button div 'map' does't display map in the place where bottom div disappeared. It displays map with the same size.
Leonid,
<!DOCTYPE html>
<html>
<head>
<style>
html,
body {
height: 100%;
width: 100%;
margin: 0%;}
</style>
<script>
require([
"dojo/domReady!"
], function(
parser.parse();
basemap: "osm",
zoom: 8,
} else {
appLayout.resize();
</script>
</head>
</div>
</div>
</div>
</div>
</div>
</body>
</html>
Thank you very much for your help!
