Date and time missing when offline using related table
1095
12-01-2016 12:34 PM
BruceGodfrey
I'm using Collector 10.4 on android.  I'm collecting data in a related table.
When I'm connected and online, and I collect data, the date/time field is populated correctly.  All works well.
When I'm disconnected and go offline, collect data and sync, the date/time field is not populated - it is blank.
I'd like the date/time field to be populated the same way in both instances.
Is anyone aware of a solution?
Thank you.
-Bruce
BruceGodfrey
Worked with Esri Support. This is a known issue:
BUG-000099125: Disconnected editing in Collector for ArcGIS fails t..
A workaround is hosting using ArcGIS Server.  The issue appears to only apply to data hosting on AGOL.
-Bruce
