Jquery Datatable create a manual ID field
3861
12
12-02-2016 04:10 PM
by Anonymous User
Not applicable
Hello all,
I would like the user to be able to input an ID (same ID for all selected features) to a table via an input textbox. I keep getting mixed results.
This wont work:
var input;
 $("#tesr").change(function () {
                  console.log($("#tesr").val());
                  input = $("#tesr").val();
$.each(featureSet.features, function (index, value) {
                      row = [];
                      row.push(input);
                      $.each(value.attributes, function (index2, value2) {
                          row.push(value2);
                      data.push(dojo.clone(row));
if it is hard coded then it will work as wanted:
                      row = [];
                      row.push("22");
                          row.push(value2);
I am not sure what I am missing. Thanks,
Alex
Tags (1)
RobertScheitlin__GISP
Alex,
  In your hard coded example you are using a string "28" and in your other I am not sure if it is a string or a number. That may be your issue.
by Anonymous User
Not applicable
I tried jquery .text() but no luck. How would I pass the input text box value to string?
In js it is just .toString();
by Anonymous User
Not applicable
I finally made it work with Robert's solution.
FC_Basson
MVP Regular Contributor
Use the "keyup" event instead of the "change" event as listener for setting the value for "input".   The .val()  function should return the input text value, otherwise go old school and use document.getElementById('tesr').value
by Anonymous User
Not applicable
//keyup results
var input = $("#tesr").keyup(function () {
$("#tesr").val();
cols.push({ 'sTitle': "ID" });
//create columns
$.each(featureSet.fields, function (index, value) {
cols.push({ 'sTitle': value.name });
//create rows and push into data
row = [];
row.push(input);
row.push(value2);
Results:
[object Object]
document.getElementById('tesr').value gets me an empty column values.
Any idea why?
FC_Basson
The only output for your Results should be in the keyup function and element #tesr refers to the input and not the column values. Also, what are you trying to achieve with $("#tesr").val(); in the keyup function?
For future, can you please use the syntax editor.  Also, for your JSON objects, be consistent with the definition by using double quotes only e.g. cols.push({ "sTitle": "ID" });
by Anonymous User
Not applicable
Thank you for noticing the JSON inconsistency. Also, I would love to use the code syntax editor but dont see it in the reply toolbar.
What I am trying to achieve is to create a new ID column where the user manually input his ID value in a textbox. This column is added to a table of query results.
I have tried many ways to pass the ID values to this ID column but no success. (I have also tried the keyup function the way you describe).
FC_Basson
This is what my toolbar looks like when posting - notice the Expand toolbar option.  If you click on that you'll get an option for More, under which the Syntax Highlighter resides.  See this post for a possible reason why: where is my syntax highlighting!!! | GeoNet
