Geolocation coordinates to Point geometry to use in buffer
5089
10
12-02-2016 04:05 PM
TaylorTeske2
I am a bit new to JavaScript. I want to buffer the location of a person's position when they click the Locate Button Widget.
I modified the Locate Widget in the JavaScript API 4.0 a little bit. I am trying to get the coordinates of the position when you click the button, so that I can create a point geometry to use in a buffer. I have looked around and can't find a firm answer. I saw that you need to use the getCurrentPosition function, but some reason I can't properly implement it in my code. This is what I have so far:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Final Project</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
  <script src="https://js.arcgis.com/4.1/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #legendDiv {
      max-width: 300px;
      background-color: black;
      padding: 8px;
      color: white;
      opacity: 0.85;
    p {
      max-width: 400px;
      padding: 15px;
      border: 1px solid white;
      color: white;
      opacity: 0.95;
    #toggle {
      bottom: 20px;
      left: 20px;
      position: absolute;
      z-index: 99;
      max-width: 105px;
      border-radius: 8px;
      padding: 10px;
      color: white;
      opacity: 0.85;
    .esri-locate {
      font-size: 18px;
      background-color: white;
      color: red;
      width: 120px;
      height: 40px;
      padding: 0;
      margin: 0;
      border-radius: 8px;
      overflow: hidden;
      cursor: pointer;
    .esri-locate span {
      display: none;
    .esri-locate:after {
      content: 'GeoProcess';
  </style>
  <script>
    require([
      "esri/Map",
      "esri/layers/FeatureLayer",
      "esri/views/MapView",
      "esri/widgets/Legend",
      "esri/config",
      "esri/core/urlUtils",
      "esri/widgets/Locate",
      "esri/layers/GraphicsLayer",
      "esri/Graphic",
      "esri/symbols/SimpleFillSymbol",
      "esri/geometry/geometryEngine",
      "dojo/dom-construct",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
    ], function(
      Map,
      FeatureLayer,
      MapView,
      Legend,
      esriConfig,
      urlUtils,
      Locate,
      GraphicsLayer,
      Graphic,
      SimpleFillSymbol,
      geometryEngine,
      domConstruct,
      dom,
      on) {
      var floodLayer = new FeatureLayer({
        url: "https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/0",
        visible: true
      var volcanoeLayer = new FeatureLayer({
          url: "https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/1",
          visible: true
      var earthquakeLayer = new FeatureLayer({
          url: "https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/3",
          visible: true
      var hurricaneLayer = new FeatureLayer({
          url: "https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/5",
          visible: true
      var wildfireLayer = new FeatureLayer({
          url: "https://igems.doi.gov/arcgis/rest/services/igems_haz/MapServer/10",
          visible: true
      var shelterLayer = new FeatureLayer({
          url: "http://gis.fema.gov/REST/services/NSS/FEMA_NSS/MapServer/5",
          visible: false
      var gLayer = new GraphicsLayer({});
      var map = new Map({
        basemap: "dark-gray",
        layers: [gLayer, shelterLayer, floodLayer, volcanoeLayer, earthquakeLayer, hurricaneLayer, wildfireLayer]
      var view = new MapView({
        container: "viewDiv",
        center: [-96.050173, 39.216911],
        zoom: 5,
        map: map
      var legend = new Legend({
          view: view,
          layerInfos: [{
              layer: floodLayer,
              title: "Floods"
                 layer: volcanoeLayer,
                 title: "Volcanoes"
                 layer: earthquakeLayer,
                 title: "Earthquakes"
                 layer: hurricaneLayer,
                 title: "Hurricanes"
                 layer: wildfireLayer,
                 title: "Wildfires"
        }, "legendDiv");
      view.ui.add(legend, "bottom-right");
      var info = domConstruct.create("infoDiv", {
        innerHTML: "<p>This map presents the geospatial locations for current natural hazards events (such as earthquakes, hurricanes, floods, and wildfires) as well as the locations of FEMA shelters. <br> <br> By clicking the button, this application will geocode your location, create a 5-10 mile buffer around that location, and provide directions to the closest shelter.</p>",
      view.ui.add(info, "top-right");
      var shelterTog = dom.byId("shelterToggle");
      var wildfireTog = dom.byId("wildfireToggle");
      var hurricaneTog = dom.byId("hurricaneToggle");
      var earthquakeTog = dom.byId("earthquakeToggle");
      var volcanoeTog = dom.byId("volcanoeToggle");
      var floodTog = dom.byId("floodToggle");
      on(shelterTog, "change", function(){
           shelterLayer.visible = shelterTog.checked;
      on(wildfireTog, "change", function(){
              wildfireLayer.visible = wildfireTog.checked;
      on(hurricaneTog, "change", function(){
              hurricaneLayer.visible = hurricaneTog.checked;
      on(earthquakeTog, "change", function(){
              earthquakeLayer.visible = earthquakeTog.checked;
      on(volcanoeTog, "change", function(){
              volcanoeLayer.visible = volcanoeTog.checked;
      on(floodTog, "change", function(){
              floodLayer.visible = floodTog.checked;
      //Locate Position
      var locateBtn = new Locate({
           view: view,
      locateBtn.startup();
      view.ui.add(locateBtn, {
           position: "top-left",
           index: 0
      //Creat a symbol for buffer
      var fillSymbol = new SimpleFillSymbol({
        color: [227, 139, 79, 0.8],
        outline: {color: [255, 255, 255],
          width: 1
      //Begin geoprocessing
      locateBtn.on("locate", function(geoProcess){
          view.zoom = 15;
          navigator.geolocation.getCurrentPosition(function(position) {
              var pt = new Point ({
                   longitude: position.coords.longitude,
                   latitude: position.coords.latitude
              var buffer = geometryEngine.buffer(pt, 100, "miles");
              var bufferGraphic = new Graphic({
                geometry: buffer,
                symbol: fillSymbol
              gLayer.add(bufferGraphic);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="legendDiv"></div>
  <span id="toggle">
       <input type="checkbox" id="shelterToggle"> Shelters<br>
       <input type="checkbox" id="wildfireToggle" checked> Wildfires<br>
       <input type="checkbox" id="hurricaneToggle" checked> Hurricanes<br>
       <input type="checkbox" id="earthquakeToggle" checked> Earthquakes<br>
       <input type="checkbox" id="volcanoeToggle" checked> Volcanoes<br>
       <input type="checkbox" id="floodToggle" checked> Floods
  </span>
</body>
</html>
RobertScheitlin__GISP
Taylor,
  In your locateBtn locate event handler just use:
Var locPnt = locateBtn.graphic.geometry;
RickeyFight
MVP Regular Contributor
If I am understanding you correctly, you could use this widget in WAB instead of writing your own code.
Near Me widget—Web AppBuilder for ArcGIS | ArcGIS
TaylorTeske2
I appreciate your answer, but I need to write this in JavaScript without Web AppBuilder.
Taylor,
TaylorTeske2
I added that text, and nothing happens with my buffer. It appears the point won't buffer at all. Is there maybe something wrong with my code for the buffer?
Taylor,
  Did you use the new locPnt bar in the buffer?
TaylorTeske2
Yes, I did. See below:
TaylorTeske2
Just checked the console and I am getting an error when I try to buffer:
"The input unit and the spatial reference unit are not of the same unit type.ie Linear vs.Angular"
Any ideas?
Ok so the likely issue is that the locate graphic is geographic and the map is web Mercator so you need to use webmercatorutils to project the point to  web Mercator before you bugger it.
Stupid autocorrect that was buffer.
