Represent Two Data Points in Same Polygon
1581
12-03-2016 01:34 PM
MH11
My apologies up front if this is confusing. I am not sure how to explain it. Using ArcMap 10.4. I'm working on a project that compares two specific sets of data. One of the datasets is pulled directly from ACS and I use census tracts to join the data to my shapefile. The other dataset is pulled from a city database and does not utilize census tracts.
In a normal circumstance, one data point would link to one specific census tract. However, in this instance, multiple data points may fall within a specific census tract. Is there a way to represent two or more data points within the same polygon/census tract?
This discussion is related to...
https://community.esri.com/message/651597-create-push-pin-style-points-within-arcmap
JoshuaBixby
MVP Esteemed Contributor
"Community Help" is for help with the GeoNet community site, not for general help from the community.  I believe Esri will be changing the name to clarify.  That said, you might want to move this over to https://community.esri.com/community/gis?sr=search&searchId=c942c9f2-14c8-48b7-8ef8-e39090af336a&sea...‌.
