import csv geodata
1475
12-08-2016 08:32 AM
PeterVersteeg
Occasional Contributor II
Hallo,
I have a file with locationas and i want to import that in arcgis for desktop 10.3.1.
the location are in this format:
   -64.9734423 46.8886667 0, -64.975073 46.9527568 0,
What format is this? and what coordinate system do i need to use if i import this true create feature class true xy table.
Thank you
Tags (1)
JayantaPoddar
MVP Esteemed Contributor
Does the first row have any text (ColumnName) in it?
Looks like XYZ values in CSV file.
You could try Adding x,y coordinate data as a layer.
Spatial Reference preferably GCS_WGS1984.
Think Location
JayantaPoddar
Think Location
PeterVersteeg
 I seems I did not set the Y field earlier. Thank you for the info
AdamZiegler1
Hi Peter - I would reformat your file first. Looks like the X Y Z coordinates are separated by a comma in a run on string. I would use Notepad ++ to replace the comma and space after it with a carriage return, then replace all the spaces with commas. Then you'd have rows of properly separated coordinates. The coordinates appear to be WGS 84.
In Notepad++
  1. Open the CSV file
  2. Hit Cntrl H to open replace
  3. In the Search mode click on the Extended radial button
  4. Find: ,    (comma and a space)
  5. Replace with: \r
  6. Then Find: <space>
  7. Replace with: ,
This worked for me. I had to open the CSV in Excel and save it to a new file so that ArcMap would recognize the new format. In ArcMap, add data, add XY data. Field 1 is X, Field 2 is Y, Field 3 is Z. The points drew in Nova Scotia near a Canadian National Park.
-Adam Z
