Bug on js map ver 4.1
2104
18
12-09-2016 02:56 AM
LaxmanThapa
When map isnot placed at the top of the page, the map has following bugs
  • The zoom on mouse wheel is not centered
  • The popup on map click does not position correctly.
If I place the same map on the top of the page, then I do not have this bug.
Can someone help us solve this problem. Please click on the JSFiddle to see the bug.
Edit fiddle - JSFiddle
Tags (1)
RickeyFight
MVP Regular Contributor
Try removing the
.box{
 height:400px;
 background:white;
 outline:2px solid red;
from the css
LaxmanThapa
@Rickey That is the point. For me, the map needs to be somewhere in the middle. The 'box' is to show that there are some element like pictures, texts.
ReneRubalcava
Try absolute positions.
html, body {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
#viewDiv {
  position: absolute;
  top: 400px;
  bottom: 0;
  right: 0;
  left: 0;
.box{
  position: absolute;
  top: 0;
  left: 0;
  right: 0;
  height:400px;
  background:white;
LaxmanThapa
I cannot use absolute position because then I have to readjust the position of the map on every resize, device rotation etc etc... And I had tried it before, absolute positioning does not help. I wonder why simple thing like this is not working for esri map...
RickeyFight
Why don't you just change the 400px to 50%? Will that work?
html, body {
 padding: 0;
 margin: 0;
 height: 100%;
 width: 100%;
#viewDiv {
 position: absolute;
 top: 50%;
 bottom: 0;
 right: 0;
 left: 0;
.box{
 position: absolute;
 top: 0;
 left: 0;
 right: 0;
 height:50%;
 background:white;
LaxmanThapa
did you read my previous replies?....
RickeyFight
And when you use a % it puts the element relative to the screen...
width | CSS-Tricks
LaxmanThapa
no @Rickey, you did not understand my point. I have updated the Fiddle to make it more understandable  Edit fiddle - JSFiddle
http://prntscr.com/djm4x1
LaxmanThapa
