Unable to upgrade ArcGIS Open Data Site to 2.0
7003
13
12-09-2016 03:57 PM
deleted-user-1T_bOHag6M8d
When I attempted to upgrade my ArcGIS Open Data Site to version 2.0 nothing happens. I checked the console log and noted the error messages below.
torii-provider-arcgis.fetch called...
opendata-admin-91ef2c5….js:1 Animated Button i18n key: null for state "default"
VM480 config:1 Mixed Content: The page at 'https://opendata.arcgis.com/admin/sites/10044/config' was loaded over HTTPS, but requested an insecure image 'http://opendata.arcgis.com/favicon.ico'. This content should also be served over HTTPS.
http://opendata.arcgis.com/favicon.ico Failed to load resource: the server responded with a status of 404 (Not Found)
https://opendata.arcgis.com/api/v2/sites Failed to load resource: the server responded with a status of 400 (Bad Request)
  1. vendor-ace518b….js:8 Error: Ember Data Request POST https://opendata.arcgis.com/api/v2/sites returned a 400 Payload (application/json; charset=utf-8) [object Object] at i.t (vendor-ace518b….js:8) at i (vendor-ace518b….js:56) at n.handleResponse (vendor-ace518b….js:56) at u (vendor-ace518b….js:56) at n.c.error (vendor-ace518b….js:56) at i (jquery.min.js:2) at Object.fireWith [as rejectWith] (jquery.min.js:2) at y (jquery.min.js:4) at XMLHttpRequest.c (jquery.min.js:4)
    1. s@vendor-ace518b….js:8
      a@vendor-ace518b….js:8
      a@vendor-ace518b….js:11
      trigger@vendor-ace518b….js:15
      (anonymous function)@vendor-ace518b….js:16
      invoke@vendor-ace518b….js:3
      flush@vendor-ace518b….js:3
      end@vendor-ace518b….js:3
      run@vendor-ace518b….js:3
      join@vendor-ace518b….js:3
      u.join@vendor-ace518b….js:9
      c.error@vendor-ace518b….js:56
      i@jquery.min.js:2
      fireWith@jquery.min.js:2
      y@jquery.min.js:4
      c@jquery.min.js:4
CourtneyClaessens
Occasional Contributor III
Hi Nicholas -
Thanks for reporting this issue. Can you please provide your site url and org name?
Thank you
Courtney
Hi Courtney,
http://sjcgis.maps.arcgis.com/home/index.html
and
http://sjcgis.opendata.arcgis.com
The org name is San Juan County GIS.
Thanks.
Nick
CourtneyClaessens
Hi Nicholas,
The error is occurring because of the custom domain on your site. This is a bug and we are working on a fix, but for an immediate workaround you can temporarily remove your custom domain, upgrade the site, and add it back.
Courtney
Thanks Courtney. That worked.
ShuakeWuzhati
I am having problem upgrading the site also. Changing the custom domain didn't help.
Home | CUUATS Data Portal
and
The org name is Champaign County GIS Consortium.
I would appreciate any suggestions. Thanks!
CharlesFritz2
New Contributor III
Hi Courtney,
I also have the same problem
https://broomfield.maps.arcgis.com
and
Home | Broomfield Open Data
The organization name is City and County of Broomfield
Thank you,
Charles
CourtneyClaessens
Hi Charles,
Courtney
CharlesFritz2
New Contributor III
Thanks Courtney,
I just found this bug after sending the message on here. To re-add my custom domain will I have to re-register the CNAME with the open data domain? opendata.arcgis.com
CourtneyClaessens
As long as the domain is the same you do not have to re-register it.
Courtney
