add graphic to feature service
715
12-11-2016 02:18 AM
ofrig
does someone know if there is an option to save route from direction widget to specific feature service ?
I want ot be able to caculate a route using direction widget and save it to a feature service that will contain all my routes/
thanks'
Ofri
JonathanQuinn
Esri Notable Contributor
This sounds more appropriate for a GP service instead of the route widget.  You can set up a model or script to accept input points, create a route, and append the route to an existing dataset.  The dataset can be served as a map service which will automatically be updated when the GP service is run.
