Rotate Valves to match connecting line
4288
21
12-12-2016 05:04 PM
TimHayes1
Occasional Contributor III
I have a point feature class (isolation valves). I am using ArcGIS 10.2.2.
Each valve is on a line (pipe). The line is split at the valve.
I want to rotate the valves to match the orientation of the connecting line.
When I tried using the rotation tools in the Water Utility Network Editor Toolbar it does not rotate the valves. The older version from years ago was able to do this. But, the issue seems to be due to the fact that the line is split at the valve.
Any ideas on how to get the points to match the orientation of the line?
Tags (1)
RobBlash
Tim,
Those extra parameters would go in the ValueInfo field of the DynamicValue table, see screen shot attached.
MikeMillerGIS
Esri Frequent Contributor
What version of the add in?  There was an issue similar to this last year I believe.
TimHayes1
The version I am using is Utility Network Editing A4W - Oct 2015.
MikeMillerGIS
Try the most recent version, should be fixed in there.
TimHayes1
I downloaded and installed the most recent version of the Utility Network Editor. Tried to rotate the valves, still get the same results. The Feature Class is in a Version of a SQL-Server Enterprise Geodatabase. My data is not in a Geometric Network, but the pipes are split at each valve. The valves and lines are snapped, no topology errors.
Here is the result when I choose Rotate Selected Junctions:
Here is the result when I choose Add Rotation to Features:
MikeMillerGIS
Could you send me the map and a small subset of the data?
TimHayes1
Just sent you some sample data to your email.
RobBlash
Have you made any headway on this issue? I am having a similar problem rotating fittings. I've been using AA for years (with the same exact rule for symbol rotation) but after upgrading to 10.4.1 and AA version 7.15.2016 the Junction_Rotation method is not working as expected, instead it writes 0 for the rotation value.
RobBlash
Based on Tim's comments and my own experimenting it seems like the rotation is not working as expected where the line is split.
MikeMillerGIS
It is a bug only when using the junction_rotate method on non-geometric network features.  There is a workaround, add the layers to the rule.  The code was checking the last parameter as an empty string, but it was being pass as null.
workaround:
ex: g|0||Pipes
