Trouble authorizing ArcGis Desktop licence
1506
12-14-2016 10:56 AM
BrianMarron
I'm trying to install ArcGis 10.3.1 but I can't see the option [not] to authorize the licence. The email from ArcGis said to do the following:
When prompted, accept the default, I do not wish to authorize any extensions at this time. The extensions will be authorized automatically.
But when I open the authorization wizard I don't see the "I do not wish to authorize any extensions" option. See screen shot.
Any help would be appreciated.
Brian
JayantaPoddar
MVP Esteemed Contributor
Are you authorizing ArcGIS Desktop trial license (Single Use)? How To: Authorize ArcGIS Desktop 10 Single Use online
Else, you might like to follow the instructions in Authorizing your software—Help | ArcGIS for Desktop
Think Location
TimothyHales
Esri Notable Contributor
We appreciate your question; however, https://community.esri.com/community/help-and-feedback?sr=search&searchId=dc80cc21-1429-442d-b377-39...‌ is for questions specifically with the community. I am going to move your question to https://community.esri.com/groups/arcgis-for-desktop-installation-support?sr=search&searchId=f08b843...‌ where you'll get a better response. Thanks!
RebeccaStrauch__GISP
I think you may have already gone past it (or might be the next screen ??).  Are you trying to authorize extensions or the core software?  Did you request your authorizations from myesri?  If so, you can chose the third option and point to the file that you downloaded or were emailed.  If you already have core installed, and are trying it authorize extensions, use the middle option and you will get the page to enter authorization code for the extension.
But it sounds like this is your first install, so you will want to select option 1 or 3 ....or you can cancel out of this part, get your authorization email/file and then start the authorization process again.
Here is a help document that might help
JayantaPoddar
Think Location
