Portal License
1168
12-20-2016 12:46 AM
YigalMuntner
New Contributor III
When will Drone2Map get its license from the portal and not from ArcGIS Online?
JayantaPoddar
MVP Esteemed Contributor
I think the license for Drone2Map for ArcGIS can be managed through Portal for ArcGIS.
Drone2Map utilizes the Named User license model. Named User licenses are configured through ArcGIS Online or a local instance of Portal for ArcGIS.
Manage Drone2Map licenses
dlaw-esristaff‌, Could you confirm?
Think Location
YigalMuntner
New Contributor III
I did not see any way to use the portal for that.
DerekLaw
Esri Esteemed Contributor
Hi Yigal and Jayanta,
The last I heard on this: there are plans to enable licensing of Drone2Map with Portal for ArcGIS, but this won't happen until the next Drone2Map release v1.1 which is tentatively scheduled for sometime in 2017 Q1.
Hope this helps,
