Hi, I'm trying to publish a scene layer but appears this error in the main window. I have an administrator rol in AGOL but I can't to publish the ortomasaic and the scene layer. The portal configuration is correct (www.arcgis.com) and I sign in with my AGOL user. ¿Can you help me with this problem?
You can publish that to your active private page on AGOL as a tile layer. You must authenticate your portal on the "portals" tab when you click on the "Project" tab at top left. Right click on your portal and select "authenticate."
