LAS Dataset Point Thinning in ArcGIS Pro not available?
3010
15
12-22-2016 07:38 AM
by Anonymous User
Not applicable
I'm using a countywide LAS Dataset in an ArcGIS Pro 1.3 local scene and have found the Point Thinning options on the Appearance tab greyed out. I'm able to symbolize the layer and filter points, but I'd like to control the number of points drawn. Could it be related to the layer's caching? The LAS Dataset is to keep the cache between sessions (default, I think). Any help is appreciated.
DanPatterson_Retired
Point thinning and cache control and lastly las properties Did you try clearing it to see if it makes a difference?
by Anonymous User
Not applicable
Clearing the cache didn't activate the thinning options. They are inactive on a single tile las dataset also.
Trying the data in a new project, perhaps moved to a new location as well, is the only thing I can think of offhand
by Anonymous User
Not applicable
Any resolution to this guys?  I'm facing the same issue.
by Anonymous User
Not applicable
No solution yet. I've updated to ArcGIS 1.4 and nothing changed, even when using a smaller dataset.
by Anonymous User
Not applicable
*ArcGIS Pro 1.4
by Anonymous User
Not applicable
Too bad - I'm downloading the update right now and was hoping it would solve it!
if the issue is due to a bug... which was addressed in ArcMap 10.5 or ArcGIS Pro... there is an 'issues addressed' link in my blog.  If the issue isn't listed, then it either isn't due to a bug, or no one has reported it as a bug, or it hasn't been fixed yet.
/blogs/dan_patterson/2016/05/09/the-links
by Anonymous User
Not applicable
Thanks. I don't see the issue in those documents, so I'll go through tech support. My last two tests were to move the las file and try it without constraints (other users I know have reported problems with constraints). Neither fixed the problem.
