How do I get the default size of a map popup? (JSAPI 3.x)
1537
12-27-2016 10:43 AM
DirkVandervoort
Occasional Contributor II
I working on map.infoWindow.resize(x,y) to resize my map popups based on the type and amount of content. This has begged the question:
What is the default size of a map popup and how do I obtain this value?
TIA
SarojThapa1
Occasional Contributor III
By default, the content area for an info window is 250 pixels wide and 100 pixels high. If you have the required modules and objects to call InfoWindow Popup, the default size will be displayed. Or Use
map.infoWindow.resize(250, 100);
RobertScheitlin__GISP
Dirk,
   There are undocumented properties to get that info.
map.infoWindow._positioner.offsetHeight;
map.infoWindow._positioner.offsetWidth;‍‍
