How to run the Nodejs server to connect ArcGIS Portal App?
1942
12-27-2016 07:36 AM
MathanManohar
New Contributor III
I want to build app using WAB. I had installed the nodejs[server]/WAB in the desktop. I setup the ArcGIS Portal in the organisation. I can create the application in the Portal account. Now I have to connect the Portal application in the desktop WAB for customization.
Query:
How to run the node js server in the desktop?
How to link the application which is created in the ArcGIS Portal and customising using WAB in desktop?
JayantaPoddar
MVP Esteemed Contributor
RebeccaStrauch__GISP
If you need additional tips, also check out /blogs/myAlaskaGIS/2015/01/15/tips-and-observations-for-getting-web-appbuilder-developer-edition-ins...‌  and /blogs/wab/2015/05/01/installing-robert-s-enhanced-search-widget-for-the-web-appbuilder?sr=search&se...‌   which has a very good tutorial on getting things setup and running.  These are both based more on using the AGOl AppID vs Portal, but should be the same similar process, and the res of the info should work for both.
