Black screen in Arcgis Earth version 1.3 build 1472
1552
01-11-2017 12:52 AM
ThomasPetri
I can't see the Arcgis Earth when I start the application. I can add layers and I can see the coordinate system is the right one, but there is only a black screen:
I have directX11.1 installed
And there is no proxy server:
Any tips on what to do?
DanPatterson_Retired
You need Direct X 11 for sure, just check the driver status again and version
check https://community.esri.com/message/583830
There are other links on GeoNet you can check just do a search here using 'black screen' for all references to driver issues
ThomasPetri
Hi Dan.
I checked the conversations and I'm sure that:
- there's not running any proxy server
- i'm running DX11
could it be something else
If you are sure... I will flag CAndrews-esristaff‌ to see if anything else has been added to the list
ThomasPetri
I'm sure, thanks
