Agisoft - Arcscene: Bizarrely blocky georeferenced models
1508
01-11-2017 06:07 AM
DeanConnor
My query focuses on the transfer of photogrammetry  models out of Agisoft Photoscan into Arcscene, where i can add geophysical data to them once the model is built. Out of photoscan i have two models; one referenced within local coordinates (position from reference datum in photoscan) and one that is georeferenced to WGS 1984. When i import the models into Arcscene (10.4) the local coordinates model loads fine, yet the georeferenced model imports as a bizarrely blocky model. I can't find a definite answer as to why this is anywhere that works!
Both models are exported in .dae formats and stored as multipatch feature classes within the same geodatabase. Georeferenced model is on the left of the attached file.
Any help would be greatly appreciated! Thanks
ErikKjellman1
You need to edit the georeferenced model and replace it with the local model. See from Photoscan to Arcscene - YouTube  for a detailed workflow.
DeanConnor
Hi Erik,
Thank you for getting back to me on this matter! I've seen that youtube video before and followed the workflow exactly as it details, unfortunately that still didn't work for me. Instead the model was unchanged and still just as blocky as it had been.
