Screen is blank when I create a project
1973
12
01-13-2017 07:57 AM
RyanPurdy
When I login to Workforce and create a project I don't get an error but I don't see the project on the screen.  The screen says I have no projects and to create my first project.
If I try to create the project again it says it already exists.  So I login to Arcgis Online and there is a folder in My Content with the project name.
Is there something I am missing?
CraigGillgrass
Hi Ryan,
Are you still seeing this issue?  If so, I have some steps I'd like to ask you to go through to try and narrow down the issue.
Craig
RyanPurdy
Hi Craig,
I am now seeing a permissions error on my end.  It says I don't have access to the resource.  This might be something I have to talk to our administrator about?
CraigGillgrass
Ryan, can you send me the permissions error?  You can send it to me directly.
Craig
RyanPurdy
I get an error when I try to send the message.  Here is a screenshot.
CraigGillgrass
Ryan, it does look like your permissions are not sufficient to create Projects.  Here's an overview of the minimum privileges required to create projects:
- Groups - Create, update and delete
- Content - Create, update and delete
- Content - Publish hosted feature layers
- Sharing - Share with groups
- Features - Edit
Can you confirm that you have these privileges?
RyanPurdy
I'll have to talk with our administrator but from the list you provided I can assume it's the groups privileges that I don't have.  I can use Survey 123 and Collector without any issues.
CraigGillgrass
Let me know how it goes Ryan,
MeenuSaharan2
HI Craig,
I'm administrator of my portal, however still facing same issue.
Please advise me. Thank you.
CraigGillgrass
Hello Meenu,
What release is your Portal?
Are you seeing the exact same error as Ryan was above?  Can you send a screenshot?
thanks,
