Lidar into Veg Classifications
2096
5
01-13-2017 02:09 PM
RickeyFight
MVP Regular Contributor
Is there a tool that I can use Lidar to create Vegetation classifications?
I am looking for types such as Douglas Fir and Madrone.
I am not looking for:
Ground
Low Vegetation
Medium Vegetation
5
High Vegetation
Tags (3)
DarrenWiens2
MVP Honored Contributor
There's no single tool that will do this for you, as far as I know. You generally need additional information (multispectral imagery, terrestrial ecosystem/forestry mapping, etc.) to build a model, incorporating things you know about what you want to model (height, density, smoothness, reflective characteristics, etc.).
ArthurCrawford
Hi Ricky,
Not sure the exact steps I would take, but you should look at taking your building footprints and running the Extracting Buildings and Trees from Lidar tool (BuildingTreeIdentification_V3.zip)   on my blog along with Trees as points (Trees From LIDAR and NAIP_Pro.TBX.zip).   Next, I would use the classification tools with imagery.   Segmentation tool seems to be a good way of classifying the result.   I would add those as a field to the points and then try to do a group analysis using slope, segmentation, height, width, and maybe NDVI range.   I tried this several years ago with some success.  Here's an area I segmented:
And then the tree points with attributes run through a group analysis.   The Red Triangles were points that are power lines or over water.   You can see that different trees species are grouping with the different colors below.   You really need ground truth data to do this properly.
You have my number/email if you want to contact me.   I have not had time to further this research lately.
Once you have the points with the groups of trees identified, it would be simple to buffer the trees to a polygon and then using the polygons to classify the points based on height.
Arthur Crawford - Esri
RickeyFight
acrawford-esristaff,
I will try this process and let you know if I have any issues.
Thank you!
ChrisDonohue__GISP
A quick "heads up" in case this is a new type of analysis for you - set aside time beforehand to determine what level of accuracy will be acceptable given your project needs and then during the analysis definitely ground truth your results.  It is not uncommon with this type of analysis to mis-classify large amounts of data.  Expect to do several iterations as the process gets refined. I'd start with a small plot where you already know what trees exists there and see what the analysis says it is, then tweak the settings/process to improve the results.
Also, there always will be some level of error.  The question that will need to be answered is what level of error is acceptable.
Chris Donohue, GISP
RickeyFight
acrawford-esristaff What version of arcmap/pro do I need to run the two tools you have provided?
