complete added field by model builder
1271
01-14-2017 02:46 PM
MartinHoben1
Hey guys!
Is it possible to complete an added field by the model builder? Or have I do it manually?
Thanks!
DanPatterson_Retired
drag the tool into modelbuilder Add Field—Help | ArcGIS Desktop
and just specify the parameters... if they are to remain the same, you just specify them once and they will be used again... obviously the field names must differ
MartinHoben1
Ok, but I want to fill in the field manually. How is it possible within the model builder?
make what you want to fill in a model parameter
ChrisDonohue__GISP
Another option is following Add Field to tag on a Calculate Field (Data Management) tool and then populate the field using the appropriate expression in the tool.
Calculate Field—Data Management toolbox | ArcGIS Desktop
Chris Donohue, GISP
