Survey123 Standalone
956
5
01-18-2017 02:34 AM
JohnMcConalogue
New Contributor III
Does anyone know can I create a Survey as a standalone on my PC i.e. I don't have to connect it to the cloud?
Thanks.
JamesTedrick
Esri Esteemed Contributor
Ah, thanks,
With Survey123, you can use a PC to take surveys in a standalone environment, but the data storage is still tied to either ArcGIS Online or an ArcGIS Enterprise organization; either is required to publish a survey.  It is possible to install ArcGIS Enterprise on a single PC (I've done that routinely for demonstration purposes), but if you're only using it for Survey123, you aren't getting a lot of value out of it- Survey123 is designed to complement a data/mapping system, not be an independent application.
JamesTedrick
Hi John,
Survey123 is designed to work in either a cloud or on-premise enterprise environment; it requires either ArcGIS Online or an ArcGIS Enterprise organization to store the data.  Given you're other question on public surveys (https://community.esri.com/message/659893-survey123-public?et=watches.email.thread ), I'm a little confused- a public survey would need to be accessible over the network and thus a standalone PC would not be a great deployment target.
JohnMcConalogue
New Contributor III
Thanks for the reply James.
Apologies for the confusion but they are two separate questions for different scenarios.
I have one survey I want to enable the public to utilise from a website and am wondering how I go about doing this?
The other question is, if I just want a standalone survey without any network access is this possible?
Thanks.
JamesTedrick
Ah, thanks,
JohnMcConalogue
New Contributor III
Thanks for your reply James.
On my other question would you have an answer, can I publish my current survey so that members of the public can fill it in and how can I do this?
Thanks.
ZoltanKovacs4
John
This blog post from Ismael details how to create a public survey.
https://community.esri.com/groups/survey123/blog/2016/11/10/getting-started-with-public-surveys
I hope this helps.
