Public story map asking for login
4852
8
01-19-2017 06:19 AM
AnaHiraldo-Gomez
New Contributor III
I am at a lost here.  I shared a story map with everyone, all layers and web map are also shared with everyone, still when I share the link it is asking people to login..  Any ideas?
Local Perspective
OwenGeo
Esri Notable Contributor
Ana -- Stephen's point sounds like the most likely cause of your issue, but the best way to troubleshoot and fix issues with your story maps is to use the My Stories section of the story maps website. This tool will find and flag issues with sharing or missing content in your stories and also lets you authorize subscription and premium content as well.
You can read more about My Stories in these blog posts.
Owen Evans
TimWitt2
Ana,
when you go to your organization settings under security did you check the
settings?
Tim
AnaHiraldo-Gomez
New Contributor III
Tim,
Yes it is checked.  Also I have a number of other story maps we share with the public and have no issues.  Only this one.
StephenSylvia
Or do you have premium or subscriber only layers in your app? Even if these layers are public, they will still require a login. If this is the case, you can choose to store your credentials on the server with the app so public won't have to login. See step 5 of the help here: Add items—ArcGIS Online Help | ArcGIS
OwenGeo
Owen Evans
AnaHiraldo-Gomez
New Contributor III
Thanks everyone,
I finally gave up and started using WebApp Builder instead.  It's a lot more flexible.  I didn't have any subscription and premium content.
OwenGeo
Ana,
Sorry you are still having difficulty. Are you sure you are using a story map? The link in your original post uses the Local Perspective app, which is not a story map.
Was that the correct link? If you still have the story map you were working on, could you share the link?
Owen
Owen Evans
AnaHiraldo-Gomez
New Contributor III
Thanks Owen,
You are correct, didn't get that far.  It was meant to be used in the content for a story map so technically it is in the wrong group.
HenryUnderwood1
New Contributor III
I ran into this one today and it turned out to be an external map service below:
When I clicked on that item I got an error message:
Strangely, the map seemed to display the layer just fine. I removed the layer from my map and added a new WMS layer (https://tigerweb.geo.census.gov/arcgis/rest/services/TIGERweb/Places_CouSub_ConCity_SubMCD/MapServer...)  and now I do not receive the login message anymore.
