Is there an Extract Data Widget?
3400
6
01-19-2017 10:38 AM
MichaelWestbrook
Trying to find an Extract Data Widget to use like we had in Flexviewer. We use the webpage so the Engineers can download a custom map for AutoCad. Any help is appreciated.
Tags (1)
KarenLizano
New Contributor III
You can publish an extract data task as a geo processing service (publish it from your geoprocessing results window) then use it in your geoprocessing widget in WAB.
KarenLizano
New Contributor III
MichaelWestbrook
Thanks, That worked perfect. Now if I can figure out printing I'll be good.
KarenLizano
New Contributor III
try this https://esri.jiveon.com/docs/DOC-3841  works great!
MichaelWestbrook
I tried this tool from the demo page and looks great. I just can't figure out how to implement it. Any help is appreciated.
Drew
Occasional Contributor III
Just in case you have not heard about "ArcGIS for AutoCAD" (free)...
You can not extract but you can view map services and more..
ArcGIS for AutoCAD Overview
Drew
KarenLizano
New Contributor III
If you can get that arcgis for autocad plugin to work consistently, its great.  Good Luck
