aligning data frame
1249
01-20-2017 09:02 AM
ΝίκοςΒαβλάς
Hello everyone i am having some trouble with my map on layout view. When i try to adjust the size of my data frame the shapefiles that it consists change size proportionally and i cant align my map with the print boarder. Is there any option i can change that?
AbdullahAnter
Occasional Contributor III
I think that the following link will be helpful:
Customizing your map extent—Help | ArcGIS Desktop
ChrisDonohue__GISP
Less likely, but worth checking if all else fails- check if your data and Data Frame all have a coordinate reference system applied.  If some do not, they can change unexpectedly as you zoom in and out.
Chris Donohue, GISP
