How can I render Douglas Fir trees
1036
01-20-2017 04:12 PM
DougBrowning
MVP Esteemed Contributor
In the help page here it says Douglas Fir should be a tree type.
Supported tree genus types—ArcGIS Pro | ArcGIS Desktop
But in Pro I only see this
What am I missing?
DanPatterson_Retired
common name, genus, species
Douglas Fir,  Pseudotsuga, Menziesii
not a pine (pinus) ... would changing the genus or trying the common name or species change things?
DougBrowning
All I have to pick from is the drop down list I posted here so not sure what you mean?  There is no way to change anything else.
DarrenWiens2
MVP Honored Contributor
You can add a new field, populate with "Pseudotsuga", and use that as the Type. I haven't found a way to add to the shortened drop-down list.
