Export Mosaic Dataset and maintain mosaic operator
1287
01-23-2017 06:01 PM
WarrenMedernach
Occasional Contributor III
How can the mosaic operator (blend in this case) be maintained when exporting a mosaic dataset to an image?  If I try to Export Data it isn't retained, and Copy Raster fails without any real message.
Tags (1)
CodyBenkelman
What version are you running?
Check the "Use renderer" option and also change the default NoData value from 256 to 0 (presuming 8 bit data)
This should apply the blend operator - let us know if this doesn't work.
WarrenMedernach
Thanks for the response Cody, and sorry for the delayed response... The image I'm trying to proves is quite large and hung up the machine a couple times over the last day.  I decided to try this on a small section to see if it works, but unfortunately  this isn't working... at least not with a Mosaic Dataset.
I'm running ArcGIS 10.4.1.
The original mosaic'd image with the blend looks like this:
Using the following:
This is the result:
I noticed you did not have the Force RGB toggle on, but when this is toggled off it generates and empty raster.
