How to access element in geoprocessing value object?
2737
9
01-23-2017 08:30 PM
TieshengWu
HI all
I am puzzled by a simple problem.  I don't know how to access a point object's x and y coordinate from a  arctoolbox in  python script.
It can be accessed  this way:
pnt=arcpy.GetParameterAsText(0).split()    # c1 is a point object in arctoolbox interface
x=float(pnt[0])
y=float(pnt[1])
It's not ideal because the code will fail when the x and y are inputed in different decimal seperator, say ',' format.
So I use:
pnt=arcpy.GetParamete(0)
But what's the method to get pnt.X and pnt.Y?
FC_Basson
MVP Regular Contributor
Have a look at this help description: http://pro.arcgis.com/en/pro-app/arcpy/classes/point.htm
Then to read the geometry:
point = arcpy.GetParameter(0)
ptGeometry = arcpy.PointGeometry(point)
x = ptGeometry.X
y = ptGeometry.Y‍‍‍‍‍‍‍‍
TieshengWu
Thank you Basson. Line 2 return: RuntimeError: Object: CreateObject cannot create geometry from inputs.
arcpy.AddMessage(type(point)) show:  <type 'geoprocessing value object'>
FC_Basson
It leaves the question of how your point object is defined?  Is it a string?  Please provide more information on the tool.
TieshengWu
FC_Basson
coords = str(point).split(' ')
x = coords[0]
y = coords[1]
arcpy.AddMessage(x)
arcpy.AddMessage(y)
TieshengWu
The x and y will be used as float, so decimal seperator problem still exists.
FC_Basson
Your decimals should be in point notation (12.3456) and not comma notation (12,3456), then the Python code works.
TieshengWu
Than you Basson, but I am tring to write a tool not only for myself.
FC_Basson
So your issue is with the regional settings of the OS for decimal number notation.  You can detect what format the user's OS is showing floats with
locale.localeconv()['decimal_point']
