How do i clip a raster data to produce a smooth edge
2784
01-25-2017 01:19 PM
Kofi_Lartey
New Contributor III
I have clipped a large raster data set but instead of the usual smooth edge , i now have a rough edge. Other clips produce a smooth edge. What should i do to obtain a smooth edge for my clipped data?
Tags (1)
DanPatterson_Retired
the smooth edged one is for a much larger area... you just can't see the expected cell layout.  The rough edged one, is for a much smaller area (or much larger cell size) and it is showing what is expected.
Why are you concerned about this? The display of raster cell edges is expected behaviour
Kofi_Lartey
New Contributor III
Dan i think you were right, i had applied what i thought was the solution to a diferetn data set, so you were right. My appologies
Kofi_Lartey
New Contributor III
I solved the problem by using the environment settings for the clip to raster tool in arcgis. In the Environment setting i used the the same processing extent as the snap to raster and the problem was solved. Thanks any way for the audience.
SteveCole
From a strictly visual perspective, you can also change the ressample method for a given raster layer in Arcmap from Nearest Neighbor to Bilinear Interpretation (Layer Properties->Display tab). It won't alter the underlying data but generally makes a more pleasing visual by getting rid of the "pixely" appearance.
