Hi there! I am an user from Chile and I am struggling to generate a Attachment Match Table in ArcGIS Pro.
762
01-27-2017 01:30 PM
LaurentSantos
To be more precise, I need to attach pictures to a point feature class In ArcGIS Pro.
I am trying to use the Attachments toolset but I am not able to generate correctly an Match table.
How do I manage to set up this table? how do I fix a Match path field?
Thank you in advance!
Laurent Santos
Tags (1)
AdamZiegler1
Hi Laurent - If I understand you correctly you have photos and want to attach them to the points. If that is correct, you'll want to 'Enable Attachments' in the geodatabase. This will create the attachments table for you and manage the join fields behind the scenes. To add attachments you use the 'Attachments' tab in the Attributes window.
The Add Attachments below is for linking your features to a folder of images, as long as you have the image name as a field.
Hope this helps,
Adam Z
LaurentSantos
Hi Adam,
It works - thank you very much!
Just a little advice: the help from ArcGIS Pro is not clear about this task. Seems that a little revision may be valuable.
Thank you very much for your help!
Laurent Santos
