Static maps with ArcGIS Server 10.4 __by URL__
2233
10
01-30-2017 08:26 PM
PitersonPaulgek
New Contributor III
We want to use static maps with ArcGIS Server 10.4
And found "ArcGIS Service Similar to Google Static Maps API" - GitHub - esri-es/Static-Map-Service-ArcGIS: This service allows you to get a static map through an U...
Please explain how to publish the service to the ArcGIS Server.
Any help, please.
PitersonPaulgek
New Contributor III
Another question about URL
String.Format("http://staticmapservice.herokuapp.com/?center={0},{1}&zoom=5&size={2}x{3}&maptype=streets&markers=color:orange|{4},{5}&format=jpg", latitude, longitude, AWidth, AHeight, latitude, longitude);
does not show markers. Why?
PitersonPaulgek
New Contributor III
How can I publish a Javascript script as a print service?
PanagiotisPapadopoulos
Use the Export Map from a Dynamic Service. The rest end point allow you to create static images from the map. See here
https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/export?bbox=-232.699730...
You can see all the available parameters here
Export Map (Census)
Help about how to use this rest end point is available here Export Map (Operation)
FC_Basson
MVP Regular Contributor
The REST endpoint could be used in conjunction with the Search widget (Search | API Reference | ArcGIS API for JavaScript 3.19 ) to perform a similar map export request for place name searches as in the GitHub example provided by piterpaulppp‌ in the original question post.  After getting the results from the Search widget, the map export URL can be constructed and executed to generate a static map when using a place name in the static map request URL.
PitersonPaulgek
New Contributor III
Thank you Panagiotis PapadopoulosFC Basson
You made really good points.
How I add marker or line to Export Map?
Sorry, but can I do static map with the https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2Fesri-es%2FStatic-Map-Se...
If yes, please explain how to publish to ArcGIS Server
Also don't forget the Javascript Print task
Print | ArcGIS API for JavaScript 3.19
ArcGIS Server has a print service for this and Javascript API a ready to use Print Widget, see here
Printing in web applications—Documentation (10.5) | ArcGIS Enterprise
PitersonPaulgek
New Contributor III
We only need the URL solution
PitersonPaulgek
New Contributor III
If yes, please explain how to publish to ArcGIS Server.
Any help please
FC_Basson
You must first install GIT and also Node and NPM, then just run the command line install instructions as provided on the page.
