The specified coordinate exceeds the valid coordinate range
2391
7
01-31-2017 09:01 AM
DanMattheis
I have a feature dataset (SpaceUse) with two feature classes (floor_space and int_walls).  All interior wall features are within floor_space polygon features, both have the same extent.  When I import them into SDE, floor_space draws fine, but int_walls throws the "The specified coordinate exceeds the valid coordinate range" error.  I'm using 10.3.1.
DanMattheis
Problem resolved!  A tool that was feeding me data was forcing M and Z values.  Disabling M and Z values in Environments resolved the problem.  Thanks to those who took the time to help.
DanMattheis
Hi Asrujit,
I looked, none of these seem to be at the root of my problem.
Asrujit_SenGupta
MVP Regular Contributor
Is the issue reproducible if you have the Feature class outside the Feature Dataset?
DanMattheis
Sorry for the slow response.  I get the same result whether the feature class is in the dataset or not.
AbdullahAnter
Occasional Contributor III
It could be solved, if you increase False Easting or False Northing. but may be cause geometry Error.
So
I Think this question should be shared in Coordinate Reference Systems Group.
DanMattheis
Changing the False Easting/Northing is not an allowed where I'm at.  Good thought though.  Thanks for the input.
DanMattheis
