Surface Volume - single file output
864
02-03-2017 06:47 AM
BartłomiejEjdys
Hi everyone!
I am currently doing some calculations involving volume and surface of water in a river valley, using a raster DEM dataset. I was thinking about using Surface Volume (3D Analyst) tool, but encountered a problem.
According to the tool help, it's possible to obtain results for multiple runs of the tool in a single .txt file. Quoting the help:
"If the same output file is specified in multiple runs of the tool, the pre-existing records are maintained and the results are appended to the table."
However, when trying to select an existing .txt (containing results from a previous calculation), I get an "Error 000725 Output Text File: Dataset [...] already exists".
Thus the question is - does this actually work the way it's described in the help, or am I doing something wrong here?
Using ArcMap 10.4.1.5686 Advanced
Thanks in advance for any help.
DanPatterson_Retired
moved to https://community.esri.com/community/gis/3d?sr=search&searchId=31d2d338-ab39-467d-bb97-e322ec03489d&...‌ so it doesn't get ignored in GeoNet help... which is the landing place about getting help on using GeoNet
