OrderBy not working on Qt
1733
5
02-10-2017 07:33 AM
Marco_AlejandroBonilla
Hi all,
We're tying to obtain the last 10 records added to a Feature Layer.
We're using OrderBy to accomplish this task but it's not working.
Please, any help is more than welcome.
        QueryParameters{
                whereClause: "1=1"
                maxFeatures: 10
                orderByFields: [ OrderBy { fieldName: "OBJECTID"; sortOrder: Enums.SortOrderDescending} ]
        map.operationalLayers.get(0).featureTable.queryFeatures(paramsQuery);
result:
qml: OBJECTID 7959 IDInstalacion SAN000001A
qml: OBJECTID 7960 IDInstalacion SAN000002A
qml: OBJECTID 7961 IDInstalacion SAN000003A
qml: OBJECTID 7962 IDInstalacion SAN000004A
qml: OBJECTID 7963 IDInstalacion SAN000005A
LucasDanzinger
Esri Frequent Contributor
Marco-
I tried your code and it works for me (the order prints out descending). Then, I realized that I am testing with a local build of Update 1, and not the 100.0 final release. This is a bug with the final release of 100.0 that we have recently fixed, and that you will get with the release of Update 1. Apologies for the confusion!
-Luke
LucasDanzinger
Hmm, it seems to be working from my test. Maybe you can share a repro case with some test data? Here is what I am doing:
QueryParameters {
    whereClause: "1=1"
    maxFeatures: 10
    orderByFields: [
        OrderBy {
Then I have a test function:
// tests orderBy QueryParameters in queryFeatures
function test_0253_ServiceFeatureTableQueryFeaturesOrderBy() {
    serviceFeatureTable.queryFeatures(orderByQuery);
    compare(serviceFeatureTable.queryFeaturesStatus, Enums.TaskStatusInProgress);
    verify(Utils.waitForTaskStatusCompleted(serviceFeatureTable, serviceFeatureTableUnitTests, "queryFeaturesStatus"));
    compare(serviceFeatureTable.queryFeaturesStatus, Enums.TaskStatusCompleted);
    while (serviceFeatureTable.queryFeaturesResult.iterator.hasNext) {
        var feature = serviceFeatureTable.queryFeaturesResult.iterator.next();
        console.log(JSON.stringify(feature.attributes.attributesJson))
And this prints out:
qml: {"GLOBALID":"96BB8A4A-F847-441E-B5BD-FCFC4D0ED336","OBJECTID":12303,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"3BB033A3-B4B6-4407-835A-A43A4028240F","OBJECTID":11892,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"0757C598-4FE4-4DDD-A71F-5F5B6D9A1188","OBJECTID":11891,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"24F0E648-BC2E-4D2B-A5E2-BC037D173DE1","OBJECTID":11890,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"1EA5D5D9-9086-4E8A-B490-9E394678C2B8","OBJECTID":11889,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"9EEAAA46-3C3C-4716-A30E-8603DCD6A7F3","OBJECTID":11888,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"2BA75D97-978B-4690-A70B-9D4EC6698213","OBJECTID":11887,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"EB41D73F-207F-40F2-9221-9FAEBCE25068","OBJECTID":11886,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"E6131832-2F87-4D66-8ADD-1B3681D864D8","OBJECTID":11505,"PLACENAME":null,"TYPDAMAGE_INT":1}
qml: {"GLOBALID":"E8BAE8E2-DE99-4DEE-A326-D9F1AEB82C96","OBJECTID":11504,"PLACENAME":null,"TYPDAMAGE_INT":1}
If I switch to ascending, I get this:
qml: {"GLOBALID":"8B68F79B-1B4D-4139-89F4-3EF532EA9957","OBJECTID":3,"PLACENAME":null,"TYPDAMAGE_INT":3}
qml: {"GLOBALID":"D11EA625-F08C-4535-9482-DD4ACB080FB9","OBJECTID":804,"PLACENAME":"Q bld","TYPDAMAGE_INT":5}
qml: {"GLOBALID":"3124D0B1-E56D-405E-BC63-2A162654C29E","OBJECTID":807,"PLACENAME":"H bld","TYPDAMAGE_INT":3}
qml: {"GLOBALID":"81B3E1EA-09BA-4600-B359-C4A68051CF41","OBJECTID":808,"PLACENAME":"HR","TYPDAMAGE_INT":1}
qml: {"GLOBALID":"EF6C4488-7AC4-4345-A454-BC04D5C4DC16","OBJECTID":813,"PLACENAME":"Esri","TYPDAMAGE_INT":5}
qml: {"GLOBALID":"A409DC80-715F-4504-A553-A1701EFBD354","OBJECTID":814,"PLACENAME":"Storage","TYPDAMAGE_INT":2}
qml: {"GLOBALID":"01203C5F-A4D1-4B29-87B1-4060E3C15CFC","OBJECTID":815,"PLACENAME":"Palm Springs Aerial Tramway","TYPDAMAGE_INT":1}
qml: {"GLOBALID":"53DD78A1-AA0E-4077-BDF7-63EBB5394634","OBJECTID":1201,"PLACENAME":"Benjarong","TYPDAMAGE_INT":5}
qml: {"GLOBALID":"2E0BC8FD-5095-426B-A2FC-2B0C0B21D86F","OBJECTID":1207,"PLACENAME":"Esri","TYPDAMAGE_INT":4}
qml: {"GLOBALID":"F6C38A29-BAE8-47B5-90A8-CB0C53BAE845","OBJECTID":1208,"PLACENAME":"Esri","TYPDAMAGE_INT":2}
Hi Lucas,
Thanks for your reply.
We don't know if we're missing anything but it's not working for us. Here's our code and, as you can see, is being run on an arcgis sample service.
import QtQuick 2.6
import QtQuick.Controls 1.4
import QtQuick.Controls.Styles 1.4
import QtQuick.Dialogs 1.2
import Esri.ArcGISRuntime 100.0
import Esri.ArcGISExtras 1.1
ApplicationWindow {
    width: 800
    height: 600
    property real scaleFactor: System.displayScaleFactor
    // Map view UI presentation at top
    MapView {
        anchors.fill: parent
        wrapAroundMode: Enums.WrapAroundModeDisabled
        Map {
            BasemapTopographic {}
            initialViewpoint: ViewpointCenter {
                center: Point {
                    x: -11e6
                    y: 5e6
                    spatialReference: SpatialReference {
                        wkid: 102100
                targetScale: 9e7
            FeatureLayer {
                // feature table
                ServiceFeatureTable{
                        url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2"
                        onQueryFeaturesStatusChanged: {
                            console.log("status", queryFeaturesStatus)
                            if(queryFeaturesStatus === Enums.TaskStatusCompleted){
                                while (queryFeaturesResult.iterator.hasNext) {
                                    var feature = queryFeaturesResult.iterator.next();
        Button {
            text: "Find and Select"
            enabled: serviceFeatureTable.loadStatus === Enums.LoadStatusLoaded
            onClicked: {
                query();
    QueryParameters{
       whereClause: "1=1"
       maxFeatures: 10
       orderByFields: [
           OrderBy {
               fieldName: "objectid";
    // function to form and execute the query
    function query() {
        // start the query
This is the result we get:
qml: status 1
qml: status 2
qml: {"objectid":12,"state_name":"Oregon"}
qml: {"objectid":11,"state_name":"Minnesota"}
qml: {"objectid":23,"state_name":"Nevada"}
qml: {"objectid":13,"state_name":"New Hampshire"}
qml: {"objectid":14,"state_name":"Iowa"}
qml: {"objectid":15,"state_name":"Massachusetts"}
qml: {"objectid":16,"state_name":"Nebraska"}
qml: {"objectid":24,"state_name":"Utah"}
qml: {"objectid":17,"state_name":"New York"}
qml: {"objectid":18,"state_name":"Pennsylvania"}
cc jimy cuesta
LucasDanzinger
Marco-
-Luke
Lucas,
Thanks for the info, maybe you know when the update is being released?
Marco B.
