Parcel Drafter: drag to rotate and scale not working
1184
02-13-2017 12:15 PM
ChelseaRozek
MVP Regular Contributor
Created a Parcel Drafter application with Developer WAB 2.3. Everything seems to be fine, except once we create a parcel we can't drag to rotate or scale. Typing it in works. There are a couple parcels drawn in the middle of Lodi Township (SW of Ann Arbor) to test with. In the console, you can see "Uncaught TypeError: Cannot read property 'x' of null" when rotating and "Uncaught Error: Illegal Argument Exception" when trying to scale.
Any ideas on what might be wrong here? Thanks
ChelseaRozek
Update for anyone else experiencing this: Turns out it's an issue with using a basemap in our local projection. Our parcels and lines are also in this local projection. When I use an ESRI basemap (web mercator aux sphere), I am able to drag to rotate. The issue has been marked as a bug.
ChrisBuscaglia
Chelsea -
Can you please open a tech support incident for this issue so that we can get to the bottom of it?
Thank,
Chris
Local Government Team
ChelseaRozek
Hi Chris,
     Do you know if this might be fixed in the next release? It doesn't seem to have been included in the June release.
Thanks!
Chelsea Rozek
ChelseaRozek
