Configuration conflict with PerfTools
1271
02-14-2017 11:36 PM
rbae
New Contributor III
If the PerfTools Add In is installed, the Start Page of my custom configuration is skipped.  It loads the Splash Screen and goes straight into ArcGIS Pro, creating a new project by default (i.e. MyProject_).  Is there a setting that will allow PerfTools and the Start Page to co-exist?
IanSims
Ryan--Denny, our developer on this, has examined what happens when
/config:ConfigWithStartWizard
is passed on the cmd line.  It turns our PerfTools does not process this cmd, but it mistakenly thinks it needs to execute a script so PerfTools creates a project.  This causes the custom configuration to skip its start page.
As a workaround, you must uninstall PerfTools if you want to start ArcGIS Pro with a custom configuration.  We will be releasing an upcoming version that fixes this issue.
Cheers,
Ian S.
rbae
New Contributor III
Perfect - Thank you Ian.
