The Time Selector doesn't work on the EventsSiteMap Solution
521
02-14-2017 09:59 AM
BrianO_keefe
Occasional Contributor III
On my EventsSiteMap, built from the ESRI Solution, the Smart Editor points to the right feature class, the map allows edits, but when you select a DATE field? It only allows you to select the date, not the time. It used to allow time...
This is what I see now...
I'm getting this in Inspect on Chrome:
Which contains the following:
n
   _ssl: undefined
   log: undefined
   message: "Unable to draw graphic (null): Request canceled"
   response: Object
   responseText: undefined
   stack: "Error: Request canceled↵ at new n (http://js.arcgis.com/3.17/init.js:111:353) at http://js.arcgis.com/3.17/init.js:135:55 at g.cancel.c.cancel (http://js.arcgis.com/3.17/init.js:110:326) at http://js.arcgis.com/3.17/init.js:90:263 at http://js.arcgis.com/3.17/init.js:87:257 at b.Deferred.A.cancel.cancel (http://js.arcgis.com/3.17/init.js:106:40) at _dfdCanceller (http://js.arcgis.com/3.17/init.js:660:331) at b.Deferred.A.cancel.cancel (http://js.arcgis.com/3.17/init.js:106:40) at _dfdCanceller (http://js.arcgis.com/3.17/init.js:660:331) at b.Deferred.A.cancel.cancel (http://js.arcgis.com/3.17/init.js:106:40)"
   status: undefined
   xhr: XMLHttpRequest
   __proto__: Error
w @ js.arcgis.com/3.17/init.js:89
I'm confused. This map is on our INTERNAL ONLY server, in case that impacts it somehow?
